Macbook Air M1 Performance on Safari 14 - Section View bug but incredible performance
travis_lundytravis_lundy Member Posts: 17 PRO
Just got a Macbook Air M1 (16 GB RAM) and was amazed with the performance vs. my dated Windows machine using the Edge browser (see below). I was disappointed to see that Section View is not available on Safari 14 which ships with Big Sur as @NeilCooke mentioned it is a Safari bug but should be fixed in 14.1. So I tried it out on a 14.1 dev version of Safari and it does appear to be fixed thankfully. Any other bugs people have noticed on their Macs with Safari we need to know about? Things going well with these new desktop systems?
  • MichaelPascoeMichaelPascoe Member Posts: 2,671 PRO
    edited February 2021
    Not bad for a Mac  ;)
    Guess my dated windows laptop isn't quite as dated as yours was. It would be nice if we could have more refined numbers so we know exactly how good our devices are at using Onshape.
  • david_salyerdavid_salyer Member Posts: 3 ✭✭
    Perhaps you guys could both open a public model and do a few operations on it and report back your findings? You could come up with a benchmark that others could use to gauge the performance of their computers. I'm thinking of getting an M1 also and was wondering what the performance benefit would be.
    Great idea!
    @alnis_smidchens do you have any ideas on what a good Onshape benchmark model could be?
    @travis_lundy
    Try using chrome, I have no issues when sectioning. The M1 battery life is amazing also; I can go a couple of days between a charge.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 564 image
    Keep in mind the presence of a "+" next to the numbers indicates your card is even more capable than the test is revealing.
    https://forum.onshape.com/discussion/comment/67500/#
    Currently our graphics check page will scale workloads the same for all graphics cards and it has a set time on the test. This has the effect of capping all results at a certain threshold and gives the appearance that many cards are equivalent in capability, when in fact they are not. We do hint with a plus sign that cards are actually doing better than the test shows
