Part number propagation failed
shawn_crocker
Member, OS Professional Posts: 913 PRO
in General
Why is this happening? It happens almost every time I either fully release or submit a release. In my notifications, I receive a notification of the status of the release and immediately after the "Part number propagation failed" notification. The main reason this is an issue for me is because the configuration part number is not getting pushed into the main workspace when the error occurs. The next time I create a release that would need to bump the revision of that configuration, onshape attempts to create a new part number because the part number row only exists in the original version. I have not had much luck getting to the bottom of this problem working through support as of yet.
PS. The option "one workspace" seems to be exactly the same as "all workspaces". What is the difference between the two? Thanks for adding you input Neil.
Shawn
Could you please create a support ticket and share the document in question with support ? Please also include approximately the time at which you tried to do this release.
