HOW TO CONVERT SURFACE TO SHEET METAL?
baldo_floresbaldo_flores Member Posts: 5 ✭✭
Does any one know how to convert a surface to sheet metal?
    In whe sheetmetal feature choose the thicken option
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,866
    Each surface face must be planar though. Trying to convert a curved surface will not work.
    Alternatively, the Convert option can be used if you want to use all faces of the surface.
    The only surfaces supported are cylindrical, extruded, or planar.
  • baldo_floresbaldo_flores Member Posts: 5 ✭✭
    thank you
  • Alexy_KougermanAlexy_Kougerman Member Posts: 8
    hey
    what to do if I need to get a unfolder from a surface (single curvature)
    edited April 2021
  • lanalana Onshape Employees Posts: 728
    You can now convert cylindrical or extruded surface to sheet metal.
    the point is for my case the surface is not cylindrical or extruded, it is loft and single curvature and I need to get a unfolder
    @Alexy_Kougerman
    Then check out this resent custom feature from Konstantin
    edited April 2021
    thanks a lot @lana
    I have already contacted @konstantin_shiriazdanov and received help, it is seems to me he is a magician and a wizard...  ;)
    the FS unwrap ruled segment is that I need
    by the way the sheet metal model (fot default inerface) is a good feature, but it does not desire to know conic surfaces unfortunately
