Can a part be copied into another part
Can a part studio be copied into another part studio to be used as a tool to boolean subtract, without having to recreate it from within that part.
nav Member Posts: 258 ✭✭✭✭
Hi @imagineered Copying just a part from one part studio to the other isn't possible yet, here several posts with the discussions and possible workarounds:
https://forum.onshape.com/discussion/479/copying-parts-between-part-studios
https://forum.onshape.com/discussion/634/copy-part-in-tab
https://forum.onshape.com/discussion/380/can-one-move-a-part-from-one-part-studio-to-another-within-a-document
https://forum.onshape.com/discussion/357/how-do-i-transfer-a-part-studio-from-one-document-to-another
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions5
If you really want to make in new part studio then
1.Export that part to local
2.Import it to inside the required document
Now required part will be in new part studio and you can work on that...
