Loft ?
I am a recent user of Onshape  and learning about the sketching features , but had  a problem using the "loft" feature attempting to bridge over two geometric entities to get a smooth surface
curvature. I used the bridging and projected curve features to create loft guides. I would appreciate any suggestions as  to how to proceed.  Thanks
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    edited October 2021 Answer ✓
    @alison_gray769
    is this what you were looking for ?
    I used those two curves as PROFILES and NOT as guides. See the picture at the bottom of this post
    @alison_gray769
    By the way, it is possible to use the edges of parts to make a loft.
    In this GIF, I did not select either of the curves
    This time I tapped on the edges of the parts to use as profiles for the loft
