Improvements to Onshape - November 15th, 2021
CAD IMPROVEMENTS
CONSTANT WIDTH FILLET
Fillets can now be defined by a constant width for cosmetically pleasing transitions between faces.
RENDER OPTIONS FOR TANGENT EDGES
Tangent edges can now be visualized in the graphics window of the Part Studio. Allowing you to render them as phantom, visible, or hidden.
GENERAL IMPROVEMENTS
GENERAL TASKS AND ACTION ITEMS
We have added the ability to generate tasks in the action items tab which don’t need to reference a comment or document. Allowing you to manage tasks at large through the action items interface.
DRAWING IMPROVEMENTS
CONTROL LINE STYLE PITCH
Drawing Properties now allow for greater control of line style for center lines, hidden lines and phantom tangent lines.
ADD ALIGNED SECTION VIEW
When previously representing complex cylindrical objects in a drawing it could be arduous to clarify small nuances utilizing the regular section view. Aligned view will help you represent these parts with more clarity.
ENTERPRISE IMPROVEMENTS
DOWNLOAD USER LIST TO A CSV FILE
For bulk removal of users in Enterprise accounts we have added an option to download the entire user list, allowing you to more effectively manage licence provisioning.
NEW GLOBAL PERMISSION - MANAGE WORKFLOW
Enterprise users can now publish and debug workflows without being a full administrator.
DEBUG MODE AND AUDIT LOG
Modifying and testing workflows has just become easier with the addition of two new developer tools.
Anyone with the Manage Workflows global permission can now submit an item through a workflow in “Debug mode” by selecting a checkbox in the “Select Workflow” dialog. Debug Mode will reference the workspace of that workflow, allowing testing, debugging, and iteration without needing to publish the workflow to the entire company.
To further assist with debugging, we have added the option to “View Audit Log” within any release package. This log will contain information about events that happened to objects passing through the workflow. Note that this information is also available to Professional users as well as through the API.
PROPERTY UPDATES UPON TRANSITION
Custom workflows can now leverage FeatureScript by referencing a function in a transition action. This transition action is named "updateItemPropertiesFromFeatureScript", and usage details can be found in the Help documentation
LEARNING CENTER UPDATES
LOCALIZATION UPDATES
All of the technical briefings in the Onshape Learning Center are now available in German and French. Change the language by navigating to the article and selecting the language in the pulldown.
Onshape on an iOS Mobile Device
This new self-paced course explores using Onshape on an iOS mobile device. Learn how to sign-in, model parts, assemble components, collaborate, and manage data on the go! This course is available to all Onshape users.
Please take a moment to try out these new features and improvements and leave your comments on the Onshape Forum. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Onshape Documents and over the next few days these features will also be available in Documents created before the date of this update.
"CONSTANT WIDTH FILLET"
Thank's Onshape team!
@ james_close Sorry, it does not, at least not to assemblies any time soon. Another interesting use of FeatureScript is coming, though.
TVP, Onshape R&D
The Action Items are Enterprise only, correct? It is noted under General Improvements....
You can find Action items under the user dropdown menu. Action items are just a bit more discoverable in Enterprise since we have that Action items tab on the Documents page.
Thank you! I now see the Action Items on account drop down. When I searched help I got an enterprise linked page (see below) and that threw me off.
I also did a double-take when searching in the Help Documentation
Property Updates upon Transition - very exciting!
Still looking out for computed properties... ?
Way to go team!
Independent Onshape Consultant | Industrial Designer
But... I think I have just find the first issue with the new fillet option
This is a limitation of our constant-width fillet implementation. If you hover over the red failure, you will see that we do have a specific error string for this limitation:
It is possible to fix this, but will require a serious amount of nontrivial development on our side. We decided to ship with the limitation since the improvement provides a behavior that is otherwise unachievable and the workaround is pretty simple (splitting into separate fillet features).
Please feel free to submit a support ticket so that we can capture requests to prioritize this further improvement.
I did, but as you mentioned, this issues has a simple workaround. So don't give it too much importance
Standard users will have to use comment tasks since general tasks are in PRO and ENTERPRISE at this time. Sorry for the confusion.
I hear that Onshape is going to end the year with a big one, Evidently, it's taking a bit to get it.
Looking forward to seeing what all is in the next release.
Isn't it interesting how we never really outgrow the child in the candy store anticipation?
TVP, Onshape R&D
I really expected that the update would be a bit later this time.
The only reason I thought it might happen is that on the Innovators Insider Podcast episode 7 they mentioned talking about a new release on the next episode which I assumed was this week.
Obviously they failed to check in with you before making that statement.
Take your time and make it good.
Most of the updates have contained functionality that either
a: I didn't know I needed
b; I didn't realize I was missing
I expect the same of the upcoming release.
I/We will all try to wait patiently.
Don't worry if I held my breath I'd be dead instead of pestering you on this forum.
