Improvements to Onshape - November 15th, 2021
Ignacio_Martos_Ignacio_Martos_ Member, Onshape Employees Posts: 18 image
edited December 2021 in New in Onshape
As we near the end of the year Onshape brings an exciting new release with big general improvements to the product!
CAD IMPROVEMENTS
CONSTANT WIDTH FILLET
Fillets can now be defined by a constant width for cosmetically pleasing transitions between faces.
https://onshape.wistia.com/medias/gqii8y33az
RENDER OPTIONS FOR TANGENT EDGES
Tangent edges can now be visualized in the graphics window of the Part Studio. Allowing you to render them as phantom, visible, or hidden.
https://onshape.wistia.com/medias/jp9xob482y
GENERAL IMPROVEMENTS
GENERAL TASKS AND ACTION ITEMS
We have added the ability to generate tasks in the action items tab which don’t need to reference a comment or document. Allowing you to manage tasks at large through the action items interface.
https://onshape.wistia.com/medias/eww61cyvj8
DRAWING IMPROVEMENTS
CONTROL LINE STYLE PITCH
Drawing Properties now allow for greater control of line style for center lines, hidden lines and phantom tangent lines.
ADD ALIGNED SECTION VIEW
When previously representing complex cylindrical objects in a drawing it could be arduous to clarify small nuances utilizing the regular section view. Aligned view will help you represent these parts with more clarity.
https://onshape.wistia.com/medias/np66bcnolk
ENTERPRISE IMPROVEMENTS
DOWNLOAD USER LIST TO A CSV FILE
For bulk removal of users in Enterprise accounts we have added an option to download the entire user list, allowing you to more effectively manage licence provisioning.
NEW GLOBAL PERMISSION - MANAGE WORKFLOW
Enterprise users can now publish and debug workflows without being a full administrator.
DEBUG MODE AND AUDIT LOG
Modifying and testing workflows has just become easier with the addition of two new developer tools.
Anyone with the Manage Workflows global permission can now submit an item through a workflow in “Debug mode” by selecting a checkbox in the “Select Workflow” dialog. Debug Mode will reference the workspace of that workflow, allowing testing, debugging, and iteration without needing to publish the workflow to the entire company.
To further assist with debugging, we have added the option to “View Audit Log” within any release package. This log will contain information about events that happened to objects passing through the workflow. Note that this information is also available to Professional users as well as through the API.
PROPERTY UPDATES UPON TRANSITION
Custom workflows can now leverage FeatureScript by referencing a function in a transition action. This transition action is named "updateItemPropertiesFromFeatureScript", and usage details can be found in the Help documentation
https://onshape.wistia.com/medias/9s2c5umfyp
LEARNING CENTER UPDATES
LOCALIZATION UPDATES
All of the technical briefings in the Onshape Learning Center are now available in German and French. Change the language by navigating to the article and selecting the language in the pulldown.
Onshape on an iOS Mobile Device
This new self-paced course explores using Onshape on an iOS mobile device. Learn how to sign-in, model parts, assemble components, collaborate, and manage data on the go! This course is available to all Onshape users.
Please take a moment to try out these new features and improvements and leave your comments on the Onshape Forum. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Onshape Documents and over the next few days these features will also be available in Documents created before the date of this update.
«1
  • kai_yangkai_yang Member Posts: 5
    Would be nice to have the tangent line option for assembly studio, too.
  • shawn_crockershawn_crocker Member, OS Professional Posts: 959 PRO
    Constant width fillet is nice!  I have been uncomfortable with fillet performance many times here and in other software and did not really consider that a solution could exist.  Nice!  Disappointed that hiding tangent edges isn't available in assemblies.  Assemblies is kind of the tab I end with meaning, I most likely want to save out some clean .png's from an assembly not from a part studio.  Can hardly wait till we can create a dimension projected along a specific line.
  • james_closejames_close Member Posts: 19 ✭✭
    FeatureScript outside of Part Studio ?  I wonder if this means FeatureScript is coming to other Studio's ?  Hmmmm
  • devin_johnson79devin_johnson79 Member Posts: 12 ✭✭
    Great release! I really like the task addition which will streamline our internal processes.
  • Barry_van_WijkBarry_van_Wijk Member Posts: 46 PRO
    What am i doing wrong? I don#t see the
    "CONSTANT WIDTH FILLET"
    edited November 2021
    I believe this update earns a table flip.  (┛◉Д◉)┛彡┻━┻  Each of these are too legit.
    Thank's Onshape team!
    :o:joy:
    @ilya_baran said:
    @ james_close Sorry, it does not, at least not to assemblies any time soon.  Another interesting use of FeatureScript is coming, though.
    RENDERCAD
  • paul_chastellpaul_chastell Onshape Employees Posts: 127 image
    @Barry_van_Wijk, its an adjustment to fillet shape so rather than being a separate tab, like full round fillet, the constant width option should be on the cross-section drop down that defaults to circular.
    Paul Chastell
    TVP, Onshape R&D
    Nice improvements!
    The Action Items are Enterprise only, correct?  It is noted under General Improvements....
    www.accuratepattern.com
  • grochinogrochino Moderator, Onshape Employees, User Group Leader Posts: 44 image
    @bruce_williams
    You can find Action items under the user dropdown menu. Action items are just a bit more discoverable in Enterprise since we have that Action items tab on the Documents page.
    @grochino
    Thank you! I now see the Action Items on account drop down.  When I searched help I got an enterprise linked page (see below) and that threw me off.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    @Barry_van_Wijk, I think it's just that you're in an older part studio that hasn't been upgraded yet.  Remember the note at the bottom:
    @bruce_williams
    I also did a double-take when searching in the Help Documentation :D I'll let the documentation team know so they can make it more clear.
  • Theo_RTheo_R Member Posts: 82 PRO
    Constant Width Fillet - great for designers, thank you!
    Property Updates upon Transition - very exciting!
    Still looking out for computed properties... ?
    Way to go team!
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
    Great improvements!!
    But... I think I have just find the first issue with the new fillet option
    Un saludo,
    And in addition, the option of constant width would also be great in chamfers
    Un saludo,
    @emagdalenaC2i
    This is a limitation of our constant-width fillet implementation.  If you hover over the red failure, you will see that we do have a specific error string for this limitation:
    It is possible to fix this, but will require a serious amount of nontrivial development on our side. We decided to ship with the limitation since the improvement provides a behavior that is otherwise unachievable and the workaround is pretty simple (splitting into separate fillet features).
    Please feel free to submit a support ticket so that we can capture requests to prioritize this further improvement.
    @emagdalenaC2i
    I totally agree
    @emagdalenaC2i
    I did, but as you mentioned, this issues has a simple workaround. So don't give it too much importance
    Un saludo,
    grochino said:
    @bruce_williams
    But you can't create new tasks outside the Enterprise domain or with an Onshape Standard or Professional account, right?
    Un saludo,
  • Ignacio_Martos_Ignacio_Martos_ Member, Onshape Employees Posts: 18 image
    This option will only be available in new documents as of right now.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    grochino said:
    @bruce_williams
    UPDATE Yes you can.  It is in the action items area of your Standard or Pro account under the Avatar menu in the upper right.  They are owned by the company you are in.  If you have more questions, please submit a ticket and I can explain further.
    Standard users will have to use comment tasks since general tasks are in PRO and ENTERPRISE at this time.  Sorry for the confusion.
    En este enlace podéis ver las Novedades de Onshape en español
    https://www.youtube.com/watch?v=aVxmXIn-5PQ
    Un saludo,
  • ChuckKeyChuckKey Member Posts: 45 ✭✭✭
    Delighted to see constant width fillet addressed, particularly as I made an/(the?) improvement request (some time ago). The single chain feature is not a terrible problem.
    I have already improved several parts by removing variable fillets with all their nasty splits and anchor points.
    The tool does not seem to cope with a 'run out', for example the intersection of two cylinders of the same diameter with coplanar axes. But I suppose that there would be singularities at the two points where the surfaces are tangential.
  • ivan_skachko548ivan_skachko548 Member Posts: 2 EDU
    I've been waiting for aligned section views for so long, and now the new era begins!
  • richard_doylerichard_doyle Member, User Group Leader Posts: 290 ✭✭✭✭
    @wayne_sauder If the stars align properly, Michael and I will be doing a live version of the podcast on YouTube highlighting this release. We should know soon, and the link will be posted here in the forums.
