Adding a cover to one end of a cylinder.. (Edited for one end.)
BigJerr
Member Posts: 9 ✭
Hello everyone. I have just constructed a cylinder in Onshape and was wondering how to put a fabric cover at each open end of the cylinder. TIA.
https://cad.onshape.com/documents/e7b657fa270146613ac1402c/w/71e761a68a041e92a8d04d59/e/865c4aea3b002c9260d3d515
You created a surface model rather than a solid. If you create a solid the ends will be capped and the model will have volume. Edit the extrude feature and change the option to Solid.
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
Also, here is a great place to learn Onshape Learning Center.
How to use the Fill feature:
