I need to import a dwg/dxf logo into my model and do a cut extrude. Is this possible in OS?
carlos_cruz
Member Posts: 1 ✭
See help for more details:
For Part Studios:
Onshape can write Onshape Part Studios to:
Onshape can read Part Studios from:
Onshape can write Onshape Assemblies to:
Onshape can read Assemblies from:
Do you have access to a person with AutoCAD? If you do and have the .dwg/.dxf file they will be able to open the file and export it in either acis or step formats and then you can do the rest with Onshape.
