How to design hair brush
anna_pir
Member Posts: 14 ✭
hello there,
would like a tutorial showing how to design/create hair brush
Pls see the image , cause I need to design something like that which will be open at 45 degree, whill have spring between 2 parts
nav
Member Posts: 258 ✭✭✭✭
Hi @anna_pir have you tried the Feature Linear pattern command ?
https://cad.onshape.com/help/#linearpattern.htm?Highlight=linear pattern
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions1
Bruce
Please post how you set this up, I'm sure many can benefit from your discoveries.
Me, I would:
-design the brush in it's closed state in a part studio
-my first sketch would be on the top plane
Anna, good luck, you're in good hands with Bruce.
By the way in which format i should convert the dwg to be able to work on it throu onshape?
thanks!
I'd be starting from a new sketch, that way you will have full control
Are you happy working in inches? you can change to metric if you want.
I also uploaded billy's image into the doc for a reference. you could so do this with your drawing but will not be able to get it into the Onshape part studio.
thank u very much yes, i a happy!
and also, is there a way to make the brush teeth pointy?
https://cad.onshape.com/documents/4614845d6ad942fc91d01558/w/3e1847d5d3d144c399a9bfea/e/c89b28a5dae14ac99eddc543
Not sure how your design is but if you want to make a brush teeth pointy you can use for example the revolve command:
1. Draw the profile you want to revolve:
2. Use the revolve command
