add line break in dimension
Murray_2Murray_2 Member Posts: 12 PRO
edited January 2022 in Community Support
Is there a way to insert a dimension line break to keep drawings tidy?
The red line in the attached image is where I would like a break.
Thanks in advance.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,892
    I try to not make them overlap by removing the leader between the arrows and moving the 1.5 dim further down. You are absolutely right it should be able to do it - please create an improvement request in the category on the right —->
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,960 PRO
    No, sorry
    I never knew that was a thing
  • Murray_2Murray_2 Member Posts: 12 PRO
    oh :-), It was feature in Creo that I used all the time.
    Thanks Neil, I'll give that a go, and make the request .
  • Reilly_PalmerReilly_Palmer Member Posts: 2 PRO
    Hi Neil, how do you remove the leader between the arrows?
    @Reilly_Palmer you can only do it with an ANSI template, so if you want ISO you can start with an ANSI template and modify it to meet your ISO requirements (there is an option in the drawing properties panel to set text aligned with dimension - however, the text is still inline rather than above the dimension line which is not ideal). An improvement request to make this an option would go a long way ----->>>>
