add line break in dimension
Murray_2
Member Posts: 12 PRO
Is there a way to insert a dimension line break to keep drawings tidy?
The red line in the attached image is where I would like a break.
Thanks in advance.
Thanks in advance.
NeilCooke
Moderator, Onshape Employees Posts: 5,929
I try to not make them overlap by removing the leader between the arrows and moving the 1.5 dim further down. You are absolutely right it should be able to do it - please create an improvement request in the category on the right —->Senior Director, Technical Services, EMEA0
I never knew that was a thing
