Is Dimensioning the only way to set lines?
Is dimension the only way to label and set a line? How do I simply draw and say how long of a line to draw instead of going to the dimensioning feature and labeling everything later? I would like to do it on the fly quickly...
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
I would suggest to memorize hotkeys: D for dimension, L for Line (see the rest from ?-menu).
After big things are there sketching should be improved with possibility to just write the length of line after first point is set. I have wrote more detailed suggestion earlier with all shapes and angles etc. Not sure if I filed a ticket or just chat on the forum - but at this point there are things with higher priority waiting (imho).//rami8
https://forum.onshape.com/discussion/1261/improvement-requests-category-has-launched-voting-open#latest
My fav's are:
s for sketch
n for normal
l for line
r for rectangle
c for circle
d for dim
shift+e for extrude
p to hide planes
Remember also that when you press hotkey again it will disable tool, so if you have your finger on D you can use doubletap to disable any tool without mouse.
