Texture (New Custom Feature!)
MichaelPascoe
Member Posts: 2,655 PRO
https://cad.onshape.com/documents/46897a2d60ade8dbb04077f3/w/23398bd91a932d1432a5d204/e/201138fdd8eee8cfcd2dcac1With Texture, you can create solid body textures by clicking a surface or face.
Use pre-loaded textures, or use your own custom texture, (See the tutorial gifs below).
This feature is a derivation of Surface Pattern by @maximilian_schommer (Onshape), Thanks Max!
Not familiar with custom features? How to add a custom feature to your toolbar
If you have any texture ideas you would like me to add to the standard library selection, feel free to comment below.
Let me know what you think! All feedback is appreciated.
How to create a custom texture:
- Create a new part studio
- Add configurable variables x, y, and z
- Place the very center bottom of your part on the Top plane origin
- Constrain the x, y, and z of your part with the configurable variables x, y, and z.
Adding custom parameters:
- Inside your texture studio, create a configurable variable with any valid name that you like
- When you go to use your custom texture, click the "Add configuration" button
- Check the "Custom parameter" check box
- Type the ID of your custom parameter exactly
Texture ideas: Diamond plate, Expanded metal, and bar grating.
Twitter: @BryanLAGdesign
Onshape, Inc.
Thanks for the feedback everyone. Here is an update for you. Keep the ideas coming!
Update!
https://cad.onshape.com/documents/46897a2d60ade8dbb04077f3/w/23398bd91a932d1432a5d204/e/56e5d6543ccb1f14cf1c4a46New Textures
Requested by: @bryan_lagrange & @Brendan_LeipeltFeature Improvements
Bug fixes
Quick mode
Currently this mode works best for flat surfaces.New config menu (tab style)
This is a tab menu, not a tab selection. This means you can go back and forth between the different tabs to change settings like a standard tab style menu.Sort buttons
By default, the textures use auto scaling. If you click scale, auto scaling will be turned off and the part size will not update with your surface size unless you specify "Auto scale" with the sort button.Learn more about the Gospel of Christ ( Here )
I would like to see what you are doing with the knight.
I am using a custom texture sized exactly to the face (1x1), and when I select "Subtract" it shows the geometry changes in Yellow, but nothing happens when I confirm the texture.
I can successfully "Add" the texture to the part, but not subtract.
Without seeing the document, here are a few things you could try:
Is there a way to apply Textures to a cylindrical item with "Remove"?
It just tries to take a slice off where the texture intercepts
Yes, this should work. If you provide a link to the document, I will troubleshoot it for you.
