Top-Level Assembly State Bug?
nickolas_koe
Member Posts: 2 EDU
I have a top-level assembly composed of multiple subassemblies - on first load the assembly appears correctly, but moving to another tab and then back to the main assembly causes it to display what seems like an older version. Moving individual parts around after suppressing their mates updates them and puts them in the correct position, and refreshing onshape shows the correct assembly.
Video
Video
OptionsMatt_Lo Member, Moderator, Onshape Employees Posts: 15We have been seeing this issue and are working to address it. The current, stable workaround is to clear your local display cache and clear your browser cache0
ctrl+f5 seems to help
Rather it's just parts disappearing.
I was diving in from assembly to assembly to look at a part. When I pressed the back button to go back up the assembly most of the parts are gone.
OfCourse F5 fixes it, but this is happening very frequently now since last update at least.
this time I didn't press the back button, but just opened the assembly tab from the tab manager
Saw some problems the other day that fit with Nick's description. Wasn't just in one assembly, but the whole document.
here is one 301631
Now the problem seems a bit less frequent, and I get this notification when it occurs (and updates after a part figures itself out):
I love you all at Onshape Support. I'll let you know if I see it again. So far, I haven't seen it in a while. (Ever since I submitted a ticket, of course! Call the mechanic and the car runs like a million bucks...)
Glad you had enough information to isolate a potential cause.
