Axel Kollmenter
Axel Kollmenter
This seems like it will be an issue with period vs comma as decimal separator.
Looks like Onshape may need to add some "import settings" on file tabs so that you can set the format (for decimal separators, etc...), does the browser "know" (and report) the regional settings of OS it's running on (so that the defaults can be set accordingly)? Looks like this could be an ongoing issue...
Axel Kollmenter
Just read about your cable featurescript listed in the onsight newsletter. Very nice!
An issue I have encounter when "pin from" or "pin to" are numeric the wire route will not be generated, I think this is a variable issue
One relevant update that I would request at this moment is grouping of wires in cables to have option to be selective of what wires I can add to it (more like bundle) and to create bundle splits.
1.- When I try to group as cable some wires it goes in a weird way:
2.- Is there a plan o way to merge more than 1 wire route into 1 bundle, I have 3 different wire route:
The mate connectors on the raceway should work as long as the defined clip has a length.
At the sensor I would like to be able to hide the 3 separate conductors, is there a way to bring the cable insulation up to the end of the conductors?
I think the issue you are having is that you can't add mate connectors to in-context geometry, so you have to select edges/faces. You can copy the in-context geometry into the Part Studio using "Transform/Copy in place" then mate connectors will work.
