These are some impressive stats. I haven't seen anything else close to this.
It'd be nice if everyone did this and tell us what the FS does.
The description that is captured in the featurescript database is the documents description. Just in case you wanted to add a description for the feature scripts you're currently working on.
Case in point, icons for Custom Features don't show at all in Enterprise.
Here's a few more IR's etc. to comment and vote for:
https://forum.onshape.com/discussion/7927/ability-to-make-custom-feature-script-tool-bars
https://forum.onshape.com/discussion/18354/officially-curated-custom-features-library
https://forum.onshape.com/discussion/11474/use-release-management-to-issue-featurescripts-aka-custom-features
FS Select Click
If there's one that I've missed please post the did which can be found below in your address bar:
I'll add it to the listing.
Link to rustyshed.com
I've got the database running locally and it's pretty straight forward. Currently the example app creates an api similar to glassworks and I need to repurpose it into a sockets based app. I'm also going to update the "OS api-key" example to include a newer nodejs version and include the newer await functionality vs. using request. I'll be posting this in the OS git repository for those using express and want to switch to using the api-key method.
I'm using this opportunity to build a newer cache database which is currently quite popular. Cloud API's are being repurposed a lot these days and what I'm about to do is not uncommon. Most cache databases are implemented for speed improvements but many are created for reorganization similar to what we're doing. Currently there are approximately 10,000 feature scripts with many being added daily.
Here is an improvement request to make finding features easier: Feature Store - Improvement Request
