Simulation for all Professional licenses
For a recap of what Onshape Simulation is and how it works, please refer to the What’s New we posted (including a video) on the release day.
https://www.onshape.com/en/resource-center/what-is-new/simulation-publications-ar-view
More information can be found at:
https://www.onshape.com/en/features/simulation
Or you can watch the webinar to see a hands on demonstration here: https://www.onshape.com/en/resource-center/events/introducing-onshape-simulation-110222
Please check the above links out before you get started, as they contain a lot of useful information about how Onshape Simulation's superpowers can be experienced. We've learned over the years that simulation is extremely valuable in early design decision support, when fundamental structural design directions are being made, so jump in as soon as you can!
Finally, Onshape Simulation is not your conventional FEA tool - it does work differently and leverages modern and novel capabilities. Give it a try and find out for yourself, visit the forum for best practices/advice, and send us support tickets. We’re seeing great successes with it, and look forward to you experiencing the same.
- First of all, definitely the easiest to setup and use for simple cases! The seamless integration is really nice with the "standard" tools available right there (show/hide, transparent/isolate, exploded views, sections, etc...)
- The only thing that is a bit weird with the views is the section view: it would be nice if you didn't have the "hatch" on the section as it stops you from seeing the colors on the section plane itself...
- I know it's early days but a bit more guidance on how to use the "simulation connection" options would be nice (especially for mates other than "fasten"). It seems to let you select just about any faces from any parts in your assembly but I don't think that necessarily makes sense. I was able to successfully use it to specify the "contacts" when mating two "difficult to mate parts". For example using two MCs defined in part studios and picking the faces that should be "tied" even though they didn't quite touch so that worked well!
I'm just running into a difficult situation where I can't seem to specify a fasten area without over-defining the assembly but If I don't have a mate I get a "simulation bonded" that isn't quite what I want as shown here, not sure if there's a workaround for this...
- I experienced a couple cases where it wouldn't run because "material information was missing". I'm guessing it was because some parts still used "old" versions (although I thought I had replaced/updated all of them with "current" ones and it seemed to be caused by "standard content" but I'm not 100% sure...)
- My biggest complaint right now is that it doesn't seem to "remember" the results if you browse away. It's fine for things that run quickly but I have a test example that takes ~30min to solve so it's pretty frustrating if you browse away by error and lose the results! Even if it's completed it seems like you lose everything if you refresh or whatever...
- One thing that is currently missing that could make simulating certain things difficult is the ability to specify a displacement instead of just loads. Right now it's hard to simulate something that has some clearance for assembly but gets deformed when you tighten fasteners (or a snap fit where you know how far it need to distort for example...)
- For the deformation, it would be nice if you could control it with a slider rather than just turn on/off or animate (or at least control the animation speed). It would be even better if the color display also went from no load to full load in the process.
- I also noticed that if you "print" to download an image, you can't include the top part of the screen so you get the plot and legend but not "what" is plotted or deformation state/state etc...
Lead Mechanical Engineer @ Healing Innovations
Below is something similar to a part I was designing for a friend. It's a nylon 12 printed part that'll get pinched into a slot and I want it hold in place:
At 7N the spring collapses small enough to fit in the slot:
I wanted the spring's deformed shape to hold against the walls of the slot and added an extra rib feature to keep the spring from destorting in the region where it comes in contact with the block.
From the bottom you can see the block & spring faces become parallel when deflected:
The yield for nylon 12 is 119MPa so I'm far enough away meaning I should be able to insert the spring into the slot many times before it takes a set.
Now that FEA is going to be "free" and widely available, I'm hoping engineers use this tool as a differential tool and not as a validation tool. It's so easy to ask "is this part design better than that part design?". Validating a design, especially during a design review isn't going to be easy and many will question your results.
