upto offset
mark_biasotti
Member Posts: 123 ✭✭✭
I find it almost amusing that up-to-offset is not an end condition in Extrude. I remember that this was one of the no. 1 differentiator over ProE in 1995 and a total delighter (time saver). I say amusing because while you've not included this very important end condition in the most basic and prolific modeling command, you went and added offset to the Replace feature
Further compounding this is the fact that there is no offset surface capability (that I have found) which is what you really need to augment the lack of up-to-offset.
Mark
Mark
2
This early access program is to help us sanity check what we have put in and left out. Hopefully we have enough capabilities to qualify as minimum set of functionality needed to be productive. but we will see as more feedback comes in...
Don't blink, since what you want may just show up sooner than you think. I am not saying this will. Point is you will not have to wait for the "next rev" anymore... we are going to be able to improve and respond to our needed improvements very rapidly.
So good feedback.
/Scott
Joe - are you saying that the move face command has an option to offset a face of the model and make it a detracted surface body? In other words, you have to have a surface to start with before you can use Move Face on it?
you can only use the Move Face on existing geometry. The command will not create new geometry. You can do it in 2 steps by first using the copy command to copy the part or surface, and then use the move face.
But as you say move face is different than offset surface.
M
@joe_dunne
Hi Joe, have blinked many times since this thread. Still no unto offset in extrude...
Mark
Also upto Vertex is another handy one, I could also use up to vertex with with offset.
Its a +1 from me as well.
