Improvements to Onshape - November 21st, 2022
MehulGalaMehulGala Member, Onshape Employees Posts: 3 image
edited December 2022 in New in Onshape
In this latest update, we have improved multiple aspects of Onshape. Many of these updates have been driven by the improvement requests sent in by you, our customers. If you have improvement requests, please submit your ideas here. Let us know what you think.
CAD IMPROVEMENTS
ASYMMETRIC FILLETS
The Fillet feature now allows you to create an asymmetric round using two offset dimensions, similar to how chamfer works.
https://onshape.wistia.com/medias/asplpwcyad
PARTIAL EDGE FILLETS
The Fillet feature now allows you to control how much of the edge is included in the feature.
https://onshape.wistia.com/medias/pkk2v5u6n6
MODIFY/ADD SECTION VIEW WITHOUT EDITING EXISTING SECTION VIEW(S)
This improvement allows you to edit existing section views without toggling off the current section.
https://onshape.wistia.com/medias/wfoo49rolo
GENERAL IMPROVEMENTS
MANUAL RECONNECTION OF A SESSION
This improvement allows you to reconnect to your session after a period of inactivity without having to refresh the browser.
https://onshape.wistia.com/medias/itmq9q790s
CHANGES TO MY ONSHAPE
To reveal an ownership-first view of the data, 'My Onshape' is being changed. As a result, data ownership is now clear.
https://onshape.wistia.com/medias/q1ty3848gs
SHEET NUMBERS ON INSPECTION LIST
Inspection sheets now include a column with the sheet number where each item number, annotation, or dimension is located.
https://onshape.wistia.com/medias/003qtqw7lc
DRAWING IMPROVEMENTS
ENHANCED CONTROL OF CENTERMARKS
This improvement allows the adjustment of automatic centermark lines and the ability to extend lines.
https://onshape.wistia.com/medias/m9bali4ydf
FLAG NOTE CALLOUTS STYLE PANEL
The style panel now supports the editing of flag notes and other callouts.
https://onshape.wistia.com/medias/uo8v05yfjl
MOBILE IMPROVEMENTS (iOS, iPadOS, Android)
To reveal an ownership-first view of the data, 'My Onshape' is being changed. As a result, data ownership is now inherently unambiguous.  More details in the video outlined above under "GENERAL IMPROVEMENTS"
FULL MOBILE SUPPORT FOR EXTERNAL THREADS
External thread callouts can be created in the Part Studio for all mobile device users.
MOBILE SUPPORT FOR PUBLICATION NOTES
You can now view the notes for Publications on the mobile platform.
LEARNING CENTER UPDATES
CUSTOM RELEASE MANAGEMENT WORKFLOWS IN ONSHAPE ENTERPRISE
Check out this new course to help Enterprise administrators create custom release management workflows in Onshape. This course is available to Enterprise and Professional users.
ENHANCEMENTS TO THE ONSHAPE LEARNING CENTER HOMEPAGE
The pull down menus on https://learn.onshape.com have been adjusted to align closer with the catalog page to make it easier to navigate to content.
VIDEO UPDATES
We have more individual video updates as well! See the complete list of videos we have updated or added to existing courses:
Please take a moment to try out these new features and improvements and leave your comments in the Forum post. For a detailed list of all the changes in this update, please see the changelog.
«1
  • EvanReeseEvanReese Member, Mentor Posts: 2,649 PRO
    Love the asymmetric fillets! I can't think of a time I've needed a partial edge fillet though. Does anyone have an example from their own experience?
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    Wow! Brilliant new updates! I love the new option to edit the section view. This will definitely save some time. Also every new fillet improvement is super nice. I don´t know where I should the partial edge fillet yet, but its good to know that its possible.
    Best regards,
    Axel Kollmenter
  • OSKMOSKM Member Posts: 16 PRO
    Not sure which one to shout loudest about, Possibly asymmetric fillets..
    Fantastic set of improvements!
  • eric_pestyeric_pesty Member Posts: 2,430 PRO
    I dont' do multiple sections that often but maybe I will do it more now that it's easier to get to! The "reconnect" should save quite a bit of time as it can be annoying to have to refresh the window of a large assembly because it "expired" when you switch back to it and have to wait for it to reload.
    I could see the partial fillet being useful if you have a difficult corner and the fillet fails. You could stop it short from the corner and do a patch surface in the corner.
    You can also do some sharp looking things like this when you follow it up with a variable fillet although I am also not sure when I would actually need to do this. Assymmetric fillets will definitely open up some options!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,917 image
    Perhaps also a router path that needs to stop short. You can then finish it off with a revolve. But mostly I would use it to patch failed fillets like @eric_pesty said.
  • ramiro_soto354ramiro_soto354 Member Posts: 2 EDU
    Please add mirror  :disappointed:
  • Alex_PittAlex_Pitt Member Posts: 73 PRO
    Thanks Onshape. Good improvements. The new controls for section and the center marks are my faves :)
  • MichaelPascoeMichaelPascoe Member Posts: 2,652 PRO
    edited November 2022
    Nice work, thanks Onshape team!
    @Evan_Reese It's also useful when you need to transition from a fillet to a chamfer or another shape while on the same edge. Pretty time consuming without this.
    This new re-connect option is very nice. I feel more efficient today already.
  • Tristan_NeumannTristan_Neumann Member Posts: 15 PRO
    I really appreciate the small quality of life improvements in these updates. The ability to edit section views without having to reinstate them will save quite a bit of frustration.
  • don_williams909don_williams909 Member Posts: 146 PRO
    Arial.
    They have "mirror" in both sketches and parts.  What more are you looking for?
  • STEGSTEG Member, User Group Leader Posts: 136 PRO
    Encore des améliorations utiles! Beau travail!  :)
    Arial.
    I've been asked for my drawing text to be Century Gothic.
  • david_mcmahondavid_mcmahon Member Posts: 37 ✭✭✭
    Thanks for the updates! One question though. Why is the centermark linestyle dashed vs. a centerline?
  • JollyJolly Member Posts: 81 PRO
    Oooooh, asymmetric fillets!  A tool I didn't know I needed but suspect my injection molded parts will now never live without!  very nice.
    En este enlace podéis ver las Novedades de Onshape en español:
    https://youtu.be/2qtx4ydYrAY
    Un saludo,
  • miczechmiczech Member Posts: 8 PRO
    Edit Section Vieeeeeeeeeeeah! Finally!
    Reconnect the session - sooooooo useful for big assemblies!
    Greatest update so far! Kudos to everyone to the whole team for making it possible 🙏
  • jack_stierjack_stier Member Posts: 2 EDU
    Cool update!
  • PattabiPattabi Member Posts: 54 ✭✭
    Excellent improvements!
  • ivan_aristovivan_aristov Member Posts: 9 PRO
    Another good release.....but................
    Cone flat pattern without facets, please! Why it works so effortlessly in F360 and SW?
