Improvements to Onshape - December 12th, 2022
Jake_DelanoJake_Delano Member, Onshape Employees Posts: 41
edited January 2023 in New in Onshape
The final Onshape release of 2022 includes a holiday bundle full of CAD improvements including color mapping curvature analysis, computed properties in assemblies, and more!
CAD IMPROVEMENTS
COLOR MAP CURVATURE ANALYSIS
In addition to zebra stripes, you can now analyze surfaces using color mapping. Analysis options include Gaussian and mean curvatures, as well as maximum and minimum radii of your surfaces.
https://onshape.wistia.com/medias/46ei3qm6dr?embedType=async&videoFoam=true&videoWidth=640
AGGREGATED ASSEMBLY PROPERTIES
You can now utilize aggregated Assembly properties when working with Assemblies to get information like the total mass of your Assembly into your bill of materials.
https://onshape.wistia.com/medias/y81s2f92gh?embedType=async&videoFoam=true&videoWidth=640
FRAME END CAPS
End caps can be added to frames that you've created, allowing you to match a frame profile or its internal profile or create your own rectangular or circular cap with their own editable parameters.
https://onshape.wistia.com/medias/c3i4k9572r?embedType=async&videoFoam=true&videoWidth=640
PARTIAL FLANGE MANIPULATORS
Partial flanges are now able to be defined using sliding manipulators.
https://onshape.wistia.com/medias/fydlfoos3s?embedType=async&videoFoam=true&videoWidth=640
BRIDGING CURVE IMPROVEMENTS
The Bridging curve feature can now start in the middle of an edge and match curvature to a face. Controls have been added to edit the position along the selected edge and the tangency angle of the curve in reference to a face.
https://onshape.wistia.com/medias/ox98bkztkf?embedType=async&videoFoam=true&videoWidth=640
DRAWING IMPROVEMENTS
DRAWING FORMAT PAINTER UPDATE
The drawing Format painter has been updated to give you more control over pasting of style, tolerance and precision, and/or content for dimensions and annotations, to improve drawing workflows.
https://onshape.wistia.com/medias/hkn1va27p3?embedType=async&videoFoam=true&videoWidth=640
GENERAL IMPROVEMENTS
NEW COMMENT INDICATOR
For increased accessibility and visibility into when a new comment is added to your workspace, a new comment icon will appear on top of the Comments tab, regardless if you are tagged in it or not.
RENDER STUDIO IMPROVEMENTS
RESET GROUND BUTTON
The Environments and ground menu now includes a button to reset the ground to the lowest point on the model. See this in action in the video below.
NEW CLIPPING AND TONE MAPPING SETTING LOCATION
Settings for clipping and Tone mapping are now located under the View tools dropdown menu under the View cube.
https://onshape.wistia.com/medias/wdgc4b4bqx?embedType=async&videoFoam=true&videoWidth=640
IOS IMPROVEMENTS
AR VIEW SHADOWS
AR view now includes dynamic shadows for your model that update as the workspace changes.
https://onshape.wistia.com/medias/plaj37ia98?embedType=async&videoFoam=true&videoWidth=640
ANDROID IMPROVEMENTS
LINK SHARING
The Onshape Android application now allows you to toggle link sharing permissions.
LEARNING CENTER IMPROVEMENTS
TECHNICAL BRIEFINGS
Onshape Arena Connector Guide- A new technical briefing for Enterprise administrators who are connecting Onshape to Arena.
Updates to Navigating Onshape for New Users to include additional information about navigating an Onshape document as a view-only user.
VIDEO UPDATES
  • Frames Fundamentals course
    • Updates to the custom profiles video to include frame alignment points.
  • Onshape Surface Modeling course
    • Update to the complex surface lofting video to include ruled surface and new loft feature options.
    • Updates to the Fill surface video to include the new adjacent faces option.
  • PCB Studio Fundamentals course
    • Update to the Navigating PCB Studio layout video to include updating the Bill of Materials reference designator.
  • Introduction to Parametric Feature-Based CAD course
    • Updates to the Onshape Documents video to reflect newer interface and brand.
Please take a moment to try out these new features and improvements and leave your comments in the Forum post. For a detailed list of all the changes in this update, please see the changelog.
«1
    xTimRicexTimRice Member Posts: 59 PRO
    Happy holidays Onshape team!! Thank you for all your hard work. Love to see Assembly properties and end caps!
    Handcrafted furniture in Boston
    https://thesmoothcut.com/
    S1monS1mon Member Posts: 2,388 PRO
    Bridging curve, curvature visualization and aggregated assembly properties are fantastic... plus all the rest. This is one of the better updates.
    I just wish that Bridging curve had a G3 option, but @Evan_Reese and I are working on something which will help a lot. We may need to rework things a bit to build on some of the new stuff in here.
    Thank you.  The sheet metal partial flange will come in handy. Enjoy your Christmas Holidays, everyone.
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,178
    @S1mon: what would you do with a G3 bridging curve, given that for now our loft, sweep, fill, etc. all produce cubic NURBS surfaces, which are not G3 even internally (and of course not at boundaries)?
    emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 859 ✭✭✭✭✭
    Great update!!
    Un saludo,
    @ilya_baran
    In my experience, for surfaces to be G^N it helps a lot if the curves are G^(N+1). While it's technically not necessary, it helps a lot. And even though the surfaces are using cubic NURBS, it seems like they often have so many points internally that they start to approximate a higher degree.
    It's also often the case that when I want two surfaces to be G^2 to each other, I will only set the loft, sweep, or fill to to be tangent to each other, because choosing curvature causes the surfaces to be more tortured than I would like. If the underlying curves are G^3, then setting the surfaces tangent will often get the surfaces to look G^2 if not G^3.
    What's the chance of getting Bézier surfaces (of whatever degree), or NURBS which are degree 5 (or greater) in the future? Are cubic NURBS surfaces a limit of Parasolid or Onshape?
    sebastian_glanznersebastian_glanzner Member, Developers Posts: 401 PRO
    edited December 2022
    Wow, so many great improvements! It's like an early Christmas present.
    I can't wait to tell my father about the new feature allowing him to create frame end caps.
    Thank you, Onshape team, for a fantastic year full of such impressive improvements. Happy holidays!
    Axel_KollmenterAxel_Kollmenter Member Posts: 410 PRO
    Great new improvements! Thank you!
    Best regards,
    Axel Kollmenter
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    This is why I really don't mind waiting a little longer for a feature.
    Been asking for calculated mass in assemblies for a while.
    When they finally release it, it can do Sooo much more.
     Thank you Onshape team. Happy Hollidays
    MichaelPascoeMichaelPascoe Member Posts: 1,724 PRO
    Thanks Onshape team for all the hard work and merry Christmas!🎄
    The real question here is... WHAT IS THAT!?
    CADSharp  -  We make custom features and integrated Onshape apps!   cadsharp.com/featurescripts 💎
    @MichaelPascoe
    That's Render Challenge #3  :D
    mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 179
    Join Richard Doyle the User Group Guy and Mike LaFleche, The Professor, live on the air for our first reactions to the latest Onshape update, which includes a ton of user requests and awesome new workflows to design your products quickly and accurately.
    10:15am
    Eastern Standard Time (Boston, MA, USA)
    Regards,
    Mike LaFleche   @mlaflecheCAD
    Its a loupedeck. This thing is a massiv tool if you edit videos or photos. I´m so in love with this
    Its like an spacemouse enterprise for video editing
    Best regards,
    Axel Kollmenter
    @Axel_Kollmenter ty! That is so legit: Loupedeck CT
    Ste_WilsonSte_Wilson Member Posts: 208 EDU
    hold on....AR....wha? Shiny!  For android too? pleeeeease?
    I'll also check out the class thing!
    Rhett_RobinsonRhett_Robinson Member Posts: 95 PRO
    I love early Christmas presents!
    The simple examples at the end of these videos are very helpful. Great for learning how to actually use the new functionality.
    @mlaflecheCAD awesome.
    STEGSTEG Member, User Group Leader Posts: 77 PRO
    Encore une fois des mises à jour utiles et bien implémentées! Bravo Onshape!
    SethFSethF Member Posts: 129 PRO
    Is it just me or did all the mate connectors get bigger?
    Funny, They look smaller to me..
    john_allen289john_allen289 Member Posts: 34 PRO
    Great update Team, aggregate assembly properties are strong.
    The changelog also states:
    1. Enterprise: Add where-used data into Analytics
    I've just jumped into our analytics and can't see where or how this is applied. Any clues?
    jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers Posts: 657
    Hi john_allen,
    Currently this data is being used to help with other link and permission information.  It's debatable whether this should have been included in the changelog or not, but I like  to err on the side of more transparency.  We are hoping to leverage this information in Analytics more in the future.
    Jake Ramsley
    christian_fong360christian_fong360 Member Posts: 2 EDU
    Thank you for this update. I love using Onshape and its featres. Keep up the good work.
    JamesonBinanitanJamesonBinanitan Member Posts: 10 PRO
    Great updates
    I love the Drawing Format used for the Throttle Body.
    It looks clean and extremely easy to understand the drawing.
    christopher_dziubachristopher_dziuba Member Posts: 45 ✭✭
    Yet another feature I wanted that I didn't even have to ask for! Boss finally got a pro license for me. Keep it up people!
    parviz_aghayarov072parviz_aghayarov072 Member Posts: 7 EDU
    1.157  new addition vey useful .Thanks onshape team
