What types of CNC machines do you use?
Tormach PCNC 1100 with ATC; StepCraft Q408 with ATC; home-brew CNC router running Mach 4; Boss Laser; multiple 3D printers
What kinds of machining do you do? 2.5 axis? Mill Turn? etc.....
80-90% 2.5 axis machining of flat stock; limited multiple face machining, occasional full 3 -axis
Volume of work, is this for occasional prototyping? Or do you have machines running 24/7?
We design and build a competition robot from scratch starting in January of each year against a demanding timeline. 60-100 parts machined for the final assembly, mostly CNC. A better CAM soltion would enable us to migrate more of our prototyping work from manual milling to CNC. Our StepCraft and Tormach are used throughout the school year in our woodworking and engineering curriculum.
Who typically uses CAM in your company? Do you have a dedicated machinist? etc...
2-4 teachers and adult mentors instruct 20-30 students annually in CNC-based design and fabrication
Do you use an existing CAM solution?
Vcarve Pro for importing 2D vector files and generating 2.5D toolpaths. HSM within Fusion 360 for some of this work and more complex machining as well.
The lack of an ideal CAM solution is the major limiting factor in utilizing the CNC technology that has been provided to us. The learning curves for industrial CAM solutions are inapproriately steep for our environment. The Fusion interface is a major obstacle that very few of our students have been able to master; VCarve provides a better interface, but its feature set is a poor match for mechanical design. Our students have taught themselves to utilize a wide range of Onshape capabilities; we anticipate that they would quickly master an integrated CAM solution.
Please enable CAM within Onshape for educational users- you will be repaid many times over as our students carry their skills forward. Thank you for the invitation to describe our needs.
Shoda, ShopSabre - 3 & 4 Axis - Fanuc & Mitsubishi controller.
2.5 & 3 Axis - Materials vary from Aluminum, Aluminum honeycomb, plastics, solid surface, wood, wooden sheet goods, MDF.
Prototyping and production 8 to 12 hours daily (work week).
I do.
SW/Camworks.
Thanks.
3 axis for musical instrument making (5 axis would be great for my usecase, but I don't have access to such a machine atm.)
Just prototyping atm.
One hobbyist (me) and the MakerSpace team is reachable in case of machine related questions.
Fusion 360, VCarve, Deskproto, NC Shop Floor Programmer (Maker version)
3 axis for 2D Contur and 3D roughing/finishing
Only used when there is something to mill
One hobbyist, me and my son
before switching to OnShape I used Fusion's CAM module now Kiri Moto
By Heiko from Germany
For the time being you could take a look at Carbide create, it's free and simple
https://carbide3d.com/carbidecreate/download/
anyway thanks for the link. I would like it to be a one-stop shop like Fusion. Currently I use the KiriMoto plugin. I have created over 300 drawings that are struggling to export as dxf in OnShape. As a step import it works great. So I stay with OnShape and KiriMoto for now. KiriMoto has a few minor problems that I have already posted. Basically I would be very happy that if there will be a CAM module in OnShape, that it is also available for the hobby users.
- What types of CNC machines do you use?
Tormach 770M Mill, Tormach 15L Lathe, AVID CNC 4848 Pro router, Glowforge Laser Cutter, various 3D printers- What kinds of machining do you do? 2.5 axis? Mill Turn? etc.....
Mostly 2.5 Axis on the mill, some 2 axis turning, some 3 Axis milling- Volume of work, is this for occasional prototyping? Or do you have machines running 24/7?
Occasional. Depending on the time of year, some classes may have them running mroe.- Who typically uses CAM in your company? Do you have a dedicated machinist? etc...
Me and high school students.- Do you use an existing CAM solution?
Currently Fusion.Any other details would likely be useful to us.
I run a First Robotics Team 8051, as well as teach manufacturing classes. If we are to use this, it needs to be easy enough to learn that I can teach a brand new high school student, ideally to make something simple quickly. For the beta, I'm happy to try it myself and give feedback from this lens.
Thanks,
Matiah Shaman
Foster High School
Tukwila School District
Tukwila, WA
- What types of CNC machines do you use? Tormach, Roland
- What kinds of machining do you do? 2.5 axis? Mill Turn? etc..... 2.5 Axis
- Volume of work, is this for occasional prototyping? Or do you have machines running 24/7? Prototyping and short run production
- Who typically uses CAM in your company? Do you have a dedicated machinist? etc...Just me
- Do you use an existing CAM solution? Fusion 360, Tormach conversational
Any other details would likely be useful to us.Important that tool paths can be added to linked parts so that fixtures can be designed separately.
I wrote the Post for the Glowforge laser that turns the Fusion 360 laser CAM output into a well ordered SVG (https://github.com/garethky/glowforge-colorific-fusion360-post). But I much prefer to work in OnShape. This is something I would like to bring to OnShape as well, once we can do custom post processors.
Glowforge Laser, AVID CNC Pro 48x48
2D (laser cut & score), 2.5D (sheet goods), 3D (surfacing things like molds)
hobby projects / prototypes
n/a, I do the CAM
Fusion360
And if this helps: I pay money for Fusion360 just so I could use their import/export features so I can do all of my modeling in OnShape and use their CAM tool. But you can gladly have the $545 I pay them if I can get a good CAM tool in OnShape.
Introducing Camel: CAM for OnShape, implemented in FeatureScript
Have fun!
3-axis Workbee hobbyist Machine
2.5 Axis machining
Mostly prototyping several once a week, just getting started and plan to ramp up frequency.
I do as a hobbyist
After Graduating college Where I learned Fusion 360. I used Onshape as my personal computer wasn't strong enough for non cloud CAD. I just recently got Fusion360 again to start using its CAM feature for my new desktop CNC. I would love to just use OS as I've become so comfortable to modeling in OS.
Here's some answers to your questions:
We use a desktop CNC router, specifically the OmioCNC X8 USB.- What kinds of machining do you do? 2.5 axis? Mill Turn? etc.....
We do 2.5 axis machining. We have a 4th axis for the router but it is rarely used and is not critical functionality.- Volume of work, is this for occasional prototyping? Or do you have machines running 24/7?
We cut custom aluminum and plastic parts for our competition robots. Our volume is quite low; probably more like "occasional prototyping".- Who typically uses CAM in your company? Do you have a dedicated machinist? etc...
CAM is done by our students and mentors; we would like it to be done exclusively by our students, so an accessible, understandable tool is essential.- Do you use an existing CAM solution?
We do. We export designs from Onshape and import into Fusion 360 for CAM.The reason I ask this is that I the collision avoidance tools in CAM studio of a 3D printing project I had once thought of which was to adapt a regular 3D printer into a printer farm. The way I imagined this to work is that each part is print individually instead of the traditional layer by layer approach. In that way if something goes wrong and you have to stop the print you don't have all of your parts incomplete and have to start over. The reason that I was remind was that the collision avoidance tools could be quite helpful in this. Once you print a part it becomes a new object to avoid. With that done you could maximize the number of objects on the build plate.
What if our machines could directly get the code from Onshape to run using API. Same for 3D printing. This could be powerful.
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
I’ve used this option before to improve print quality and avoid stringing between objects. It works pretty well as long as you’re mindful of your machine clearances.
Onshape is going to have some really cool capabilities coming that are tangential to this. Like generative design. I am sure you will see more additive capabilities, built into Onshape over time. Its going to follow the market demand.
Of course these are my personal observations and opinions.
Joe
I'm another one that is mostly sheet metal so plasma/laser with sheet nesting would be a great addition
Retrofitted Vulcan plasma with hypertherm torch
2D flat sheet metal cutting
Machine runs every day for production and prototyping
Drafts person or senior sheet metal fabricator will program/nest with an operator/junior running the plasma
Old shop data systems duct cam package
Imho PTC should think about a fully featured hobby license between Free and Professional that is restricted in the amount of money you can make with it (e.g. < 10000€/year) - costing something in the realms of 10€ per month. Think that would be a big success!
I am using a CNC machine in a maker space from 2010 the original manufacturer has gone out of business and a planet machine CNC controller was put in. I also use a Prusa Mini for prototyping and will be using a laser cutter at some point but that might not be for a while
3 axis wood milling, I am mainly using MDF but I might use other types of wood in the future.
I am developing a prototype for our product. The CNC is running continuously throughout the day from different users and I would only be using it in total 8 hours within the next month. I am continually tweaking my designs though and migrating between OnShape and F360 for every change is a lot of work and I can see a lot of room for error.
Their is one main expert for the CNC but other people also know how to use it.
I am learning F360 for this project
We use Fusion360 as well as HSMworks (with Solidworks).
