Axel Kollmenter
@SethF lol a single branch sure, why not!
I really wish that one would have worked. After doing some more testing, the privatives were fine up into the millions for my simplified tree studio. So perhaps the issue was the number of mate connectors and instances. I may be able to get that to work still if I used composite parts instead of individual bristles with mate connectors. It's hard to test because it takes quite a bit of effort and then all of a sudden, BOOM, your studio is overloaded and bogged down. The rate is exponential I think from previous tests. But there is a lot going on, there are so many different variables affecting it. Part qty, mate connectors, instances, privatives, etc...
Here are the results for a Regen Sim test I did a while back related to privatives in a part studio:
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
Since we are on page 3 of this forum topic, I'll post another reminder for others who are reading:
Voting is now OPEN for all Onshape forum users!
Voting end date is March 8th.It's up to YOU! Comment below about which render you think was the most epic Christmas tree.
More forum users voting = more fun
Axel Kollmenter
Thanks @René_Sartorio & @oliver_august for the participation! This is turning out to be a fantastic render battle.
We have quite the turn out. Check out these results!
Results:
+3 @emagdalenaC2i's Ladder tree
+4 @MichaelPascoe's Traditional tree
+1 @MichaelPascoe's Lone branch
Twitter: @BryanLAGdesign
Axel Kollmenter
Both great ideas!
I like the upvote idea for settling ties. Genius.
You going to make that? That is legit.
Render Battle #2
Results:
Tie breaker:
Render with the most thumbs ups breaks the tie.And the winner is
:drum roll: 🥁🥁🥁@Axel_Kollmenter!
Congrats Axel!As a reward, you will be noted in all future render battles in the Render Battle Hall of Fame list.
Richard
Axel Kollmenter
The focus should be on the rendering itself.
I would specify views.
So all render experts can show their render skills.
Great ideas. Once Render Battle #3 is finished, we can mix it up a bit for Render Battle #4.
I'm worried I may end up being the only participant for RB#3
