Chess anyone?
Research_01
OS Professional, Mentor, Developers Posts: 301 PRO
Just had a game of chess with Jon. Of course he kicked my butt but it was fun and identified some enhancement requests.
Anyhow set up a branch copy and have a live game with someone, it works great.
It's in Public Models and called CHESS
https://cad.onshape.com/documents/e8e79d1385fd4c78be414f6c/w/6a751b49574c41e78643ed24
note: more board games to follow
Can you discuss what you are able to do to a public file since you are the author? Seems like some public files have write access and others don't.
What powers does branching give you?
Can you give an individual in the public domain rights. How do you know they are there. Can someone knock and ask for permissions?
The power of branches is locking down a key point in time and then you can continue on or make a new branch with different edits all together. Think, say, a camera model assembly, you can have one stock model, then you can have a telephoto model in another branch, and a wide angle in another.
Have you had a tour of the system?
FYI If you can send me your email (that you used to sign up to the system with) I can invite you to edit the chess set to get a better idea.
With the chess set, branches let us have different games and document them. Huh, this gave me an idea that it should be possible to have a tournament and have the branches keep score
I am not with Onshape so you may want to ask around a bit as I am not as knowledgeable as they are...
LearnOnshape facebook group
To have a tournament, you have to give rights to 2 people and let them play.
Your chess model is the perfect collaborative scenario and easily explainable to an outsider, you in sales? I see why you won, good job.
billc@rndengineering.com
Oh and no I did not win, I was slaughtered by JonH
No Bill I am but a humble freelance CAD modeler, no sales. Background in Aeronautical Engineering.
Have fun!
Ok so I got your invite and let me show you what happen:
1. 1st, I copied your public version a couple of days ago and it's in my documents:
I'm thinking this is my copy and it's independent of yours.
2. I got your link and it went into my shared folder:
What's interesting is that the shared clobbered my document and now they are the same (shared=my documents). Maybe my copy wasn't really mine.
3. If I go to the public version, it's the same as the shared & my documents
So all these chess documents I have access to are the same?
Because you shared with me, I can now create a branch:
I see the game you and Jon played. You only got 2 pawns?
I'm concerned because my original copy got clobbered, meaning it's copied by reference and not by value (it's not an independent copy, but a pointer to the original). Is this right? I have a chess in my documents, shared & public and they are all pointers to one chess document?
When I was changing the copy before accepting your shared invite, it didn't update the public chess. It was only after I accepted your invite that all became in sync.
So if you copy a public document it's yours, but if you accept a share version then the copied version is over written by the shared version?
I think this is all correct and I like it, I think.
was that how you copied? Did you rename it? if you did lets get Onshape to look into it as the shared version should be a unique instance as I understand it. I even made a copy of one public file and kept the name the same as the original and it is unique. The kinimatics in the screen cap below.
You can see this by clicking on the version tree and it will be parred down to the version of the original document you copied. See here:
Annnnd for what it is worth I got one of Jon's Bishops too, it is behind the feature list.... But that barely makes up for the fact that he kicked my butt LOL
And yes I made a copy of chess from the public view and yes it did show up in my documents and no it didn't add 'copy of' to the name.
I had an independent copy of chess until I clicked on the link you sent me.
Once I clicked the link, I got one in my shared folder.
All chess documents in public, my documents & shared are the same.
This is all confusing, I read the manual last night, but that didn't help.
Maybe someone else can shed some light on how this should work.
I see the bishop, good job!
Stuff like this they have to know about and have it in the right place like their feedback database.
Bill did you ever track down this Copy issue? If this was indeed a bug then we *really* want to find it and fix it.
It might require us to explain it better.
I'm not sure how it's supposed to work and therefore it's too hard trying to figure out if it's working. I read the manual a copy of times and I'm still not sure what's going on.
The chess game is a good collaboration and is easily understood, but it's not real. I'm more interested in having multiple engineers work on a project together.
I haven't had time to play with spending most of my getting Z to be up in my current design.
It seemed to work like you are describing and I did make a copy which was my own.
Now let's go one step further, Ben gave me rights to play him a game which ended up in my shared folder.
My versions:
1. I have a public version with no rights
2. I have a shared version with rights
3. I have a my documents version with rights.
What happened to these 3 versions when Ben sent me a link to the shared version?
They all went to the public version. I had requested the 1st move branch, but got the root. I lost the changes made in the my document version which surprised me.
Seems like I should now have 3 independent versions of the game, but I don't think that's so. I can't figure out the behavior from the manual so I kinda gave up.
I gotta get back to creating my 1st feature in OS while not bitch'n about this & that. I did get my geometry flipped. Yeah!
