Once you finish the sheet-metal part the flat pattern will not change.
This way you can add counter sinks or emboss.
if you want features to show up in the flat pattern, move those features above the finish sheet-metal feature.
There are some features that won't accept active sheet-metal parts, so if you are using finish sheet-metal as a workaround for that issue, then you may need to come up with another way to create your part, then convert it to sheet-metal last.
🕒 Más vale tarde que nunca
Onshape no para y a veces es difícil seguirles el ritmo, especialmente cuando se acumula mucho trabajo, como suele pasar a la vuelta de vacaciones.
🕒 Better late than never
Onshape never stops, and sometimes it's hard to keep up, especially when work piles up, as often happens when returning from vacation.
What's the point of writing descriptive version names if we don't have a way of seeing the information later when we need it most?
The most comical part of this is after the version updates, there's a brief time where the little success message at the top of the window actually displays the full name of the new version.
Twitter: @BryanLAGdesign
Axel Kollmenter
Improvements to Onshape - November 6th, 2023 — Onshape
