And thank goodness for the Virtual Sharps for Mates. Oh the number of times I've had to jump through hoops to mate stuff to 80/20 profiles.
I love how much this team listens to their User base.
- Virtual sharp mate connectors
- Export drawings with no Inspection Items
- Sweep profile controls
..the list goes on, there are no fillers here, all great improvements.
Have a great Christmas Onshape!
I got a "SOLVED" e-mail about a ticket from 2018/19 about the chamfer size and direction, the manuel override is a good fix. Easy to use. Thanks!
And I think the virtual sharp will also be useful when assenbling profile and other geometry.
Thank you all for the hard work you put into this (also the nice work on the videos, having an Onshape logo in the last frame, stylish!) ! I hope you have a wonderful holiday season!
Twitter: @BryanLAGdesign
Also, a huge shoutout to the Onshape development team for their incredible work. This year alone, we've seen 17 – yes, 17 – updates, each contributing significantly to the Onshape's capabilities.
En este enlace podéis ver las Novedades de Onshape en español:
Amazing work Onshape team!
RENDERCAD
LIST VIEW FILTERS
tried it out with part studio and the exact view size and orientation did not show up .....the part studio did come up with a default scale from the attempted saved scale and view......same with an assembly drawing......is a nice feature anyway. Unless I am using it wrong....as there is no video with this itemSimon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
Thank you !!
Sometimes you just have to complain and then it suddenly works by itself.
none:
lock profile face:
and a boundary surface to finish things off:
It's really hard to create basic point vector geometry using mate connectors. Mate connectors have a purpose, but it's not to create 3D geometry.
I'm thinking a new point vector geometry type that uses straight transformations which you can stack (like a robot's joints). It's simply a translation, then rotate Z and then rotate X.
Currently, when defining a mate connector, it's only translations without rotations. Try it, create a 3D curve and then create another so it's tangent to the 1st. You can align to the 3 planes, which is usually wrong, but you can't align Z to be tangent to the previous curve meaning it's lost in space without any orientation.
Does anyone know of a featurescript that creates mate connecters using standard transformations?
Are there any plans to include an option for tablet users (iPad or else) to get the same view and handling like on Mac/PC?
Also, an option, that naming/renaming a feature, automatically results in renaming the part into „featurename.x“, would be awesome!
Exploring user preferences or consulting manufacturers might refine c'sink export accuracy in Onshape's sheet metal update.
Thanks for the mate connector link. It's really close to what I'm looking for.
I'd like for it to show all the mate connectors in the transform array. The preview shows them. It's nice because it moves subsequent mate connectors when changed in the list just like a robot's arm so it's solving the transformation stack on each input change. I'm thinking rotations should come first and then translations.
I'll take a look at the code and see if I can make it my own. It's always better to start with something vs. starting from scratch.
Thanks @konstantin_shiriazdanov in advance for the seed.
