- 1st question before going too far - will they appear in Rendered images? At the 1st attempt, they don't appear in the Render Studio image of the part or assembly.
Are they meant to or is this for the future?
Innovative Woodworking Tools - www.nxtul.com
Keep up the fantastic work throughout 2024, Onshape development team!
En este enlace podéis ver las Novedades de Onshape en español:
Not sure how I missed the notification!
- New Decal feature for parts (planar and cylindrical faces)!!
- New Offset curve feature (on faces/surfaces)
- New nested feature list for Derived and Custom features in Part Studios
- New filter in the version graph to hide branches without workspaces
- Support reorder of custom properties (ie. Properties dialog order)
YES!!!!! - Support section views of a detail view in Drawings
- Support where used of a part when a part studio reference is inserted in Drawings
- Support adjusting manual centermark location in Drawings
- Added Display states feature to the View only toolbar (including Publications)
- FeatureScript: Improved performance for processing derived part studios
So happy for property reorder!I only use 5 or 6 properties, and I always have to scroll somewhere in the middle, and all the way to the bottom.
This is going to save a bunch of time!
Very happy for decals
Thanks @S1mon for your decal notes and observations!
I still haven't received any notifications from Onshape closing out the IRs.
But there are two tentative IRs on the Bingo list now:
Hole Feature Renames Itself — Onshape
textures and appearances like solidworks — Onshape
you can start by duplicating mine, then update the .csv for your needs
this creates a feature on the tree, so you can set it once, and all sheet-metal following will also follow this size.
FS:Sheet Metal Bend Table | Test (onshape.com)
To use it, just select the Bend Table feature and choose your size
all it does is create variables you can later use in your sheet-metal feature
if you want to have specific standards for sizes, such as guarding is 18ga, frames are 7ga, etc.
then you can check the "custom name" box and that will add a prefix to the variable names
here it will create #Frame_thickness and #Frame_bendRadius rather than #thickness and #bendRadius
under thickness, just enter #thickness
and for bend radius, just enter #bendRadius
If you want more sizes then download the .csv, add your sizes
then edit these areas in the code
Thanks for the nice words.
I just tried and loaded it in a RenderStudio, but the decals were not imported.
Can confirm. Brilliant find.
This is ultimately a silly work-around. Hopefully Decal will be updated in the future to be more flexible in what kinds of faces it's willing to deal with. It's interesting to note that the decal is just projected normal to the original flat surface onto the 3D surface.
I created a test where I used the same decal and the same boundary surface and I replace flat surfaces at two different angles. If you edit the "replace face" features you can see the before/after at the same time and see how the recycle symbol is being projected.
https://cad.onshape.com/documents/90a5f4a2e4c82c3112b45338/w/b4113935addb002bd1cda68d/e/db6161dcadb1e7413d83e653
