Is there a reason the version graph doesn't graphically show merges?
tom_scarincetom_scarince Member, Developers Posts: 48 ✭✭✭
Branches are nicely shown with curving lines branching off.  Just wondering why merges aren't shown with lines that way as well?  Seems obvious to me...
    I would like to see this too! I always end up creating named versions pre- and post-merge so that I can say something like "V5 - merged from V4 on B1” to keep some sort of idea what's going on.
  • andres_dandlerandres_dandler Member Posts: 17 PRO
    Hi.  I would like this too.  Is this in process?
    Thanks.
  • JollyJolly Member Posts: 81 PRO
    lougallo said:
    It is not yet implemented. We are working on showing that.
    Is deleting branches also in the words? ie: after I merge back to main I can delete the branch? That option is one reason I'm not using branching as much as I'd like. I started using it on a complicated part that requires a lot of experimental iterative testing (microfluidics) but stopped once I realized it got very cluttered.
    @Jolls - Did you know that you can delete the workspace at the end of the branch? Once I realized that, I was able to clean a lot of stuff up in my larger documents.
    edited January 2020
    lougallo said (in 2016):
    Did the dev doing the job take a long walk off a short pier?
    Probably the same Dev that was in charge of colored faces...  <3
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,874
    @Jolls @tim_hess427 you need delete permissions (usually only the document creator) to delete a branch. If the doc was shared with you, chances are you don’t have permissions, but you can ask the doc owner.
    @owen_sparks there’s quite a long pier opposite the new PTC office we just moved into, but to my knowledge no devs have gone near that yet. Merge in version graph is part of a larger body of work that will take some time to complete.
    @john_mcclary if you want coloured faces you’ll just have to patient a little while longer!
     :D
  • Aaron_EmerickAaron_Emerick Member, csevp Posts: 9
    8 years later...  Just keeping the hope alive :smile:
  • S1monS1mon Member Posts: 3,383 PRO
    Yep. This still seems like such an obvious improvement. Pretty please?
  • MichaelPascoeMichaelPascoe Member Posts: 2,434 PRO
    The Onshape Team really is amazing.  <3
