additional enhancements and general usage feedback
jeremy_luchini
Member Posts: 5 ✭✭
-when sketching on face….line tool doesn’t pick up centers of edges…
-when mating, preselected faces aren’t stored, so I lose the selection, have to add clicks
-need a distance mate
-named my parts, but part names not showing up in assembly tree.
-mate to plane?
*ball mate works well, fillets and reordering fillets work well.
-upload image as a ‘thumbnail’ of project to share, move the image to the first tab - inconsistent thumbnail creation….doesn’t always default to first tab…
-when browsing in large feature tree, right click menu gets hard to read (buried under top toolbar) sometimes…can’t access some commands…..have to zoom out google chrome, retry…
-hide/show mate annotations would be nice, view gets cluttered fast on mating components
-dividing not working when entering fractions in dialogs?
*nice parametric behavior when I make changes to parts in a tab…then tab back to assembly….for fast reviews of modifications…. I like the speed compared to alt+tab thumbnail approach across open files in a desktop app..
*things like projected edges, construction lines, trim tool, offset tool, finding centers of circles and lines - work great
-Mirrored features vs. Mirrored part - would be helpful.
-face selection a bit tough so far..., find myself zooming in to get a hold of faces….not edges….even very large faces….the cursor doesn’t find the face usually….
Cheers!
my public project: 'suspension system'
w/several dynamic&mate conditions across components:
parts so far: controls arms, bushings, mounts, ball joints
still to come: spindle, sway bar, coil-over shock dampers, rod-arms
alignment setup: camber, caster, tow, kingpin angle, spring rate
- You should be able to wake up midpoints of edges when sketching a line.
- Distance mating is currently done using the mate connector move option. There is an issue to make this easier tho.
- Naming parts or part Studios? If you name the parts in a part studio, those names show up in the tree.
- Thumbnails creation is done when you exit a doc or switch tabs.
- Mate annotations (mate connectors) can be hidden now.
The other issues you mentioned we are aware of and I will send you tickets on them..
Great stuff!
o Thumbnail generation is for most recently changed tab. Although a user specified thumbnail is a good idea @LouGallo
o If names don't show up in assy then that's a bug.
