Grid Extrude Custom Feature
I've just released a new custom feature called Grid Extrude (get the feature HERE).
It works like the normal extrude feature, but extrudes a network of shapes like this. I made it mostly to make networks of drafted ribs to reinforce plastic parts, but there are other uses too. You can watch the video tour HERE. Give it a go and let me know what you think!
12
Yes!
This is really nice, good job!
Can you? They're a pain to construct manually.
You can choose a triangle as the pattern, but it doesn't have the little holes at the nodes like the isogrid images I'm seeing
yes indeed. The closer you look the more it will remind you of it, because the bbox and transform math of your feature was the basis for handling the transforms. Thanks for making it and putting it out there.
Julia's Featurescripts | Isogrid (onshape.com)
I've been running into a number of bugs and limitations with this feature, as have others. I've re-worked a lot of it and I think it's much more usable now, and with better performance too.
Major changes are:
Twitter: @BryanLAGdesign
Can you add the "Starting offset" option?
I can't get it to extrude up to face or surface. It looks more like a linear pattern, all with the same end surface. Am I doing something wrong?
Notice that in the middle, it appears to be working ok
Any advice would be appreciated.
Thank you.
Hi Evan, and thanks for the great video and plugin! This is the first plugin I've used with onshape, and it's super cool!
I'm using it to texture 3d prints.
I have noticed a few things that might be broken or could be improved:
1/- the outline feature doesn't work for me
2/- if I try to use the plugin on multiple faces, it only usually works on the first one chosen
3/- if I try to use variable names, they don't 'take'. I would love this to work so after I add the 20 or so features to all the different faces, I can tweak them with variables.
Thanks again for the plugin!
Matt
Thanks! I'm no longer updating the feature, but I see a blue dot by yours, so you're not on the latest version. It might help with some of these things, but probably not all. The multiple faces thing won't be fixed, for example because it works just like the extrude feature.
thanks!
Really cool feature, has served me very well on many occasions. I am currently trying to use it to add a pattern with relatively large hexagons to a fairly small surface.
The issue I'm running into here is that while trying to make the length of my model parametric, I found certain edge cases in which Grid extrude leaves tiny “holes” (see pictures). In the best case, this just looks bad, but since I want to fillet this, it completely breaks the feature for some lengths.
I know you aren't updating this any more, however I thought I'd just throw this out there, in case I am missing a really obvious solution here.
Document Link: https://cad.onshape.com/documents/ac3bdac4d443b1d4aca05def/w/51b4d7859da0e1fe6c29492c/e/ecf3d234a94e3ce1d9e35123
