Pro tip: How to restore a deleted tab after you have made changes without losing work
Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 223
Ever accidentally delete a tab only to realize it is gone much later? Simply restoring before the delete will undo a lot of work. To keep your work and get that deleted tab back, you need to cherry-pick that delete action out of history.
https://youtu.be/9fX_mtd4BQk
As a recap, cherry-picking is done by:
  • Create a version of the change that you want to remove. For deleted tabs, this is creating a version after they are deleted.
  • Create a branch from the new version.
  • Restore the new branch to the moment right before the version was created (across branches). Now it is as if that moment never happened, and your tab should be in the branch.
  • Merge the branch to Main.
Support & QA
  • Theo_RTheo_R Member Posts: 82 PRO
    Thank you @Jason_S!!
    @billy2 this would probably be a relevant pro tip for the next Users Group. Consider adding to the learning center @bradley_sauln.
    Thinking may be relevant for @Evan_Reese @john_mcclary etc, if you were not already aware. Tag a friend... happy Friday.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,958 PRO
    Yea had to do this a handful of times :blush:
    Good to see it written down to spread the word
  • EvanReeseEvanReese Member, Mentor Posts: 2,477 ✭✭✭✭✭
    Woah, nice one! Never have needed this specifically, but opens up an interesting versioning branching thing I need to explore.
  • Aaron_MagninAaron_Magnin Member, Onshape Employees Posts: 116
    This is GREAT! Thanks Jason!
  • john_hauckjohn_hauck Member Posts: 54 PRO
    Maybe you should make the video 15 minutes long and ramble on so it looks as hard as I thought it was going to be. It's kind of like seeing a magic trick reveled - somehow disappointingly simple. Seriously though, thank you!
    This doesn't quite work if you have made changes to drawings.
    To do that, there is an extra step:
    Merge from Main into your branch after restoring, but before merging back into Main.
    Actually there is an easier option...
    Un saludo,
  • lanalana Onshape Employees Posts: 731
    @emagdalenaC2i
    Your process works for tab that does not have any references in the workspace, e.g drawing.  Copy/paste will create a tab with different id.  If the accidentally deleted tab was a part studio referenced by an assembly or a drawing, then merging revert of the deletion ( as Jason shown) is the only way to fix your workspace.
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 223
    This can now be accomplished with selective restore instead of playing games with branches:
    Support & QA
