Powerful workarounds
andrew_troupandrew_troup Member, Mentor Posts: 1,584 ✭✭✭✭
edited June 2015 in Using Onshape
It is likely to be some time before Onshape's Revolve command will feature advanced end conditions like "up to vertex".
I'm not even sure that Solidworks has it yet.
There's a relatively simple workaround available now: If you set up a sketch arc*, you can use it as a path to sweep the 'revolve' profile along.
The resulting geometry is analytical, and as pure as that of a revolve.
* on a plane normal to the revolve axis, ending at the desired vertex.
NOTE: it is not widely realised that the arc (or any sweep path) does not need to be anywhere near the profile being swept (or revolved, if you prefer)
This exact capability is not something which many people will end up needing, but I think it illustrates the value of striving for a fundamental understanding of what the various tools can achieve.
If you can avoid a mindset where the limitations or even absence of a particular command seem like showstoppers -- the classic "glass being half empty", a lot can be done with the fact that it is simultaneously half full.
Extruding at an angle is another task, on the face of it not possible in Onshape, which is actually very straightforward using a sweep. Again, the path can be remote from the profile.
  • andrew_troupandrew_troup Member, Mentor Posts: 1,584 ✭✭✭✭
    edited August 2015
    Someone else recently pointed out, on this forum, that the "up to vertex" end condition (similarly not yet available in Onshape) can also be simulated for an extrude, using a sweep in a similar fashion to the previous post, but with a straight line for the path.
    If the line is angled rather than normal to the sketch plane, this is a workaround for the SW "extrude at angle"
    In the interests of collecting a number of workarounds into a compact resource, a handful more:
    Project sketch to a sketch (to produce a 3D curve): extrude the sketches as surfaces, choosing for the second extrude the end condition "up to surface". The terminal edge of the second surface will be the desired curve.
    This is currently mainly useful for sweep paths, and can even be used for such things as variable diameter helices.
    To derive a sketch into the same part studio: Copy the sketch into a dedicated part studio (if there are several, you could call it something like "Master Parts") then derive the sketch back into the original studio (it would probably pay to replace the original sketch as well, so all similar sketches shared a common parent). If necessary, use "Transform" to move it into position. (Courtesy of @philip_thomas)
    To achieve the same effect as simple equations (using arithmetic or simple trig) use a dedicated sketch to carry out the operations graphically. Use the "Equal" constraint to move data into and out of the processing diagrams
    To simulate a reference axis, create a dedicated sketch on a suitably defined plane with a constrained line, and leave it visible.
    To simulate "Cut with Surface": use a surface to split a part, then delete the unwanted portion (thanks @abefeldman).
    For radial text: refer https://forum.onshape.com/discussion/1346/any-work-around-method-to-insert-radial-text-in-sketch
    To copy a part from one document to another: copy the whole part studio, then delete the unwanted parts.
    To reinstate an isolated operation (not including subsequent ops) from History: refer https://forum.onshape.com/discussion/1132/do-you-really-want-to-delete-this-parts-studio-tab-hope-your-sure
    To insert labelled milestones or landmarks in the Feature List of a long Part Studio: refer "Defined Parts" tab of this model from @traveler_hauptman :
    https://cad.onshape.com/documents/3c4e14158ece451f8d1c7318/w/6e4e129fbdab428da966d8a4/e/88e72be15478404f8307f3cd
    and for a simple way to delineate individual parts when built sequentially: Name the first feature of each new part in CAPITALS. (suggested by @da_vicki)
    And the most powerful of all: the famous "Sketch Picture" workaround: https://forum.onshape.com/discussion/504/found-a-workaround-for-sketch-picture-feature   (note the posting date)
  • kevin_quigleykevin_quigley Member Posts: 306 ✭✭✭
    I missed that Sketch Picture thing! Brilliant, if a little mad! Alternatively, now, just do it in any number of paid or free graphics apps that allow dwg or dxf  export...
    There's a nifty demonstration by @philip_thomas showing how to simulate motion in a part studio for the purposes of in-context design, in the specific case where certain positions need to be captured in the conformation of other parts. It starts about 20m into this video clip:
    https://www.onshape.com/videos/twio-multi-part
    There's a cunning workaround within it which might have broader applicability: to make multiple (more than two) "Copies in place" of a part, he uses Linear Pattern with a distance of zero.
    These copies are then moved to the desired locations using "Transform", and the incontext features created using those relocated parts.
    Naturally a dedicated Part Studio can be used for this manipulation, especially now that we have "Derive Part"
  • 3dcad3dcad Member, OS Professional, Mentor Posts: 2,468 PRO
    I'd like to add another workaround to have 'production drawings' without using drawings.
    Tip 1.
    If you have dimensions that are needed for sketch but are redundant for production you can create a copy of sketch and add only the dimensions that you need. Then exit sketch and use 'show dimensions' to get nice image.
    Tip 2.
    For imported models you can quickly add dimension sketch with 'Use/Project' tool. Add needed dimensions --> exit --> show dimensions.
    Which one do you prefer:
    edited September 2015
    Here's a crafty stopgap for the current inability to rotate a sketch, courtesy of @shashank_aarya
    https://us.v-cdn.net/5022071/uploads/editor/9k/pa841tr26ro1.gif
    edited October 2015
    Here's a barrel cam workaround supporting polar coordinates, to permit ad-hoc "wrapping" of a 2D path around a cylinder:
    https://cad.onshape.com/documents/23ea467e79014d19b4097729/w/942d64b50cdb4baf9889844e/e/6ae350e800ce47ec916a098a
    The joint lines could be eliminated (or an assymetrical groove modelled) by making the first loft a closed one, wrapping the full turn, rather than my kludged half turn
    ON EDIT: This "surface loft thru horizontal lines" method would also work to provide both a path and a horizontal parting surface for ball track toys, something recently requested on this forum
     the "up to vertex" end condition .... can be simulated for an extrude, using a sweep .... with a straight line for the path.
    Probably bad etiquette to quote myself, but what the hey!
    Here's another approach which (in some cases) might be a more useful workaround :
    A "Plane point" plane is like the end face of a (large) sketch extruded as a solid from the given plane, if you had chosen the given point as the end condition for an "up to vertex" extrusion.
    So, as a workaround the current lack of that particular end condition, you could define a plane that way, before performing an extrude.
    I think @billy had good workaround using surfaces instead of planes since they are easier to create in various positions.
    edited November 2015
    Indeed he did !
    I, too, thought it was excellent - and now I've learned the easy way to post a link to a specific message, here goes:
    https://forum.onshape.com/discussion/comment/12267/#Comment_12267
    A slow and dirty workaround for (currently unavailable) configuring features, which could still be a very useful stop-gap until we get the real thing, kindly posted by @ilya_baran :
    https://forum.onshape.com/discussion/comment/12690/#Comment_12690
    Regarding the configuration workaround: It's not quite as slow, and certainly not as dirty, in reality as in the imagination.
    Scroll down that same thread for a wonderful animated gif  @lougallojust posted, showing a simple but potent application of  Ilya's suggested method.
    I reckon it wins hands down in living up to the description of the title of this thread.
    BTW: Anyone else with decent workarounds is welcome to submit them directly here, or PM me first if you think they might not be fully worked out and want a second opinion.
    Another recent and interesting workaround from @ilya_baran was for conics. Here's how it looks for a parabola.
    In the first graphic, the highlighted line is the axis of the revolved cone, which is then "Split" by a plane parallel to the generator line for that cone.
    Here the highlighted line is the sweep path, which enables the parabolic edge to be turned into a surface, which can be used directly (eg by thickening), or as a tool (to split another body, or extrude up to, or a bunch of other possibilities)
    I learned a couple of things:
    1) An edge can be"extruded" as a surface (without first being converted to a sketch), using the workaround further up this thread, of substituting a sweep for an extrude.
    2) A sweep path (if it uses a sketch line) cannot be a construction line.
    To create a planar (flat) spiral (Archimedean):
    https://forum.onshape.com/discussion/comment/12830/#Comment_12830
    To check for breaks in a chain of entities:
    https://forum.onshape.com/discussion/comment/13281/#Comment_13281
    To work around the current absence of Assembly Planes: the Origin has an integral Mate connector
    (Thanks, @matthew_menard  !)
    https://forum.onshape.com/discussion/comment/13367/#Comment_13367
