Select Configuration States using the URL?
Hi all.
Please forgive me if this has been discussed elsewhere.
I was wondering is it, or will it be, possible to select a PartStudio Configuration via its URL?
Example:-
Here I have a dummy part with a pair of configurations.
What I'd like to be able to do is have a non cad user be able to open a configuration directly from a hyperlink along these lines:-
cad.onshape.com/documents/12345/w/678910/&HoleQty3&BracketWidthLarge
Background:-
I'm changing roles within my company and will no longer be designing stuff.  Instead I'm building some software to handle the thousands of possible configurations our products can be ordered in.  This will allow our sales team to see what it is they're asking for and for our purchasing and production departments to understand what has been sold...
Long term this might end up as a web portal using the Onshape API to return configurations, but shorter term it'll be a desktop application.  An easy win from my point of view would be for my system to build a string for the configured part/assembly and spit it to a web browser.
Thanks all,
    I think @billy2 has done something very similar on rusty shed.
    edited December 2019
    Yea, his site is verrrry nice using the API's.
    I have a steep learning curve for some other stuff at the moment so don't intend diving into the API's for a while.  Hoping the URL method will be viable as that's pretty simple, but still allows all the conditional logic and numpty-proofing to be contained within my software so isn't dependent on Onshape doing the working out what to show, just the actual showing of the "dumb configuration".
    Cheers, Owen S.
  • TimRiceTimRice Member, Moderator, Onshape Employees Posts: 315
    Currently the only way to get the config url is to open the Share dialog with whatever config you want active and then momentarily turn on Link sharing:
    This adds the config parameters to the url.
    Onshape, Inc.
    Thanks for the reply.  I was worried you'd say that. :/   With an infinite number of potential configurations that unfortunately doesn't fit this particular use case.  (Sales personage sitting with a customer and building their quotes / orders in front of them.)
    Just out of interest if I were to be able to mimic what the link would contain had I have created it manually as above, would my constructed link work, or does the process above set some stuff on your end?
    Cheers, Owen S.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
    Absolutely it works. Don't forget you can rename input tables from the 3 dot menu => "Edit FeatureScript IDs..." to make URLs easier to construct.
    Hi Neil.
    That's AWESOME :)
    Thanks fella :+1:
    For anyone following along we can edit the ID's as Neil indicated above.  Below you'll see some friendly names have been set both for the configuration option's description and the possible values.
    Which in turn gives a friendly URL parameter like so:-
    (Question) Just out of interest what does the "%3D" represent?
    Also to answer my own question above.  I used the "generate link" with in the share to get "config1" as a URL and was able to edit that and open other configs without having to set each individually.  Even more awesome.
    Happy Onshaperist here.
    Thanks folks,
    %3D is the hex ASCII character for =
    Doh, thanks Neil.
    OK, this has promise.
    Tiny demo app that will open an instance of chrome and show the user a part configured in onshape to their specification:-
    No servers, no HTML, no API, just 30-ish lines of code.
    Onshape you should be shouting how easy this is from the rooftops!
    Now to do it with some real products...
    Owen S..
    @owen_sparks
    I suppose you are feeding configurations manually into your application? Would be awesome to fetch the list from Onshape..
    I'm pretty much in same position 'code wise' as you - I can create local/web database applications but don't have enough time to dive into API even though I would like to..
    3dcad said:
    @owen_sparks
    Yeah it's all manually entered for now.  It looks like I'll have a significant amount of time to throw at this project so I'm optimistic it'll yield some good results.  The 30 lines of code has gone up a bit over the last couple of days 😉. I'll have something to demo in the new year.
    Currently I'm working with partstudios not assemblies (because featurescript, and I like PS configs). Composite parts look really interesting and so very nearly do what I need but I'm not quite there yet, or they're not, can't tell which yet!
    More to come.
    Hi folks,
    This may or may not be of interest but will post just in case it helps someone out in the future. :)
    Finally had a chance to have a look at this some more.  Initially I was just sending the url to a new instance of chrome, however this seems to be better.
    There is a Nuget package called "CefSharp" that is a wrapped version of chrome, which means that unlike the built in web-browser this one is actually WebGL compliant.
    Hardware Check:-
    Which can lead to some of this:-
    Obviously this leads to some vulnerability as far as updates to chrome but if you want a WinForms application to have some CAD data to hand this seems a reasonable approach.
    Cheers, Owen S.
    Sweet
    edited January 2020
    @owen_sparks
    Would you be able to use Microsoft's WebView2 control that uses Edge Chromium?
    https://docs.microsoft.com/en-us/microsoft-edge/hosting/webview2
    EDIT: Added URL
    Thanks @MBartlett21 I'll have a read.
    Cheers,
    Hello @harmanpa
    Thanks for the information, that look great.
    Thanks for sharing.
    Cheers,
    @harmanpa
    good job on your configurator, nicely done
    edited January 2020
    I just noticed that I still had access to Bill Schnoebelen's onshape document.
    Big deal?
    So Bill and I were working together on the idea of a web based configurator and came up with this about a year ago. It's still running. He shared a document with rustyshed that had configurations defined and I parsed the configuration tables into html, displayed on a  website and allowed web based changes to his part.
    All that was required was for him to share the document with me and in return it gave the world access to his configured document. He could change the document at any time and then the world would have more options.
    https://rustyshed.com/?route=circuitCase
    I think Owen is looking for url configuration endpoints.
    All the options under the sun will require access to a web server and a little code. harmanpa did a great job. I'm waiting for the API access call to gltf for the display list information. Currently you have to convert STL data over to webgl which is more work than necessary. harmanpa how did you do it?
    You can manually export gltf and then paste it into some code, but I'm waiting until I can download it through the API. Maybe it's possible now. I haven't ckecked lately.
  • harmanpaharmanpa Member, User Group Leader Posts: 12 PRO
    The configurator demonstrator uses STL exported for each part, the reason for exporting parts individually is that we detect the changes in the assembly structure when the configuration changes so only download geometry where necessary.
    It is however now possible to export GLTF via the API, it requires calling the createTranslation method (which is asynchronous).
    Thanks, I was looking for the method the other day and couldn't find it.
    Is GLTF the way to go? A year ago I was working on a webgl interface and read about GLTF at the khronos group. That's when I put a ticket in to get GLTF inside OS.
    With STL you don't get materials or colors; do you keep track of color, material & STL for each part? It's a lot of work to get STL working.
    I've downloaded your example; thanks for putting it together.
    Does GLTF offer up anything better?. Could you send the whole assembly and it'd render properly? Would it render like it does in OS?
    edited January 2020
    This API is a mess.....
    Here's the trail of methods available for translating an element type assembly:
    Get Element Translator Formats
    Here's the translation name GLTF listed in the returned "Body"; make sure it's capitalized.
    Create Assembly translation
    All looks good, look at the returned "Body"
    Goto the async callback location
    Says there's an error.
    Change it to translate STEP
    So I can translate a STEP but not a GLTF.
    I think I'll go back into hibernation until they clean this API up and support it better.
  • Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 117 PRO
    This is good - put as a 'Guest' user, it means I can't share and as such can't create these links. Any workarounds?
  • Caden_ArmstrongCaden_Armstrong Member Posts: 290 PRO
    @Jonathan_Hutchinson This thread is out of date.
    The copy link button in a part studio now has configuration information attached (and also the current view)
    www.smartbenchsoftware.com --- fs.place --- Renaissance
    Thank you!
