Onshape running slow or crashing on loading
                    Onshape runs fine on my desktop, but on my early 2011 Macbook pro (8 gigs ram, i5, HD3000) using chrome my entire laptop freezes up on the load graphics part of loading a document, or if it does run it works very slowly. If the part is more than a basic assembly, the laptop will lock up when trying to modify anything.
This doesn't seem like it should be happening on a laptop of this level.
I'm not sure what's going on, if maybe there is some setting I need to change?
https://forum.onshape.com/discussion/1622/onshape-running-slow#latest
Do not load any extensions if using Chrome (if I had known this I would have saved myself a lot of frustration and crashes I was blaming on my laptop)
It's an old graphics card: GeForce 7900 GS/PCIe/SSE2 and CPU: Intel® Core™2 CPU 6400 @ 2.13GHz × 2 but they are normally rock solid, if a bit slow. Perhaps they are incompatible?
I've used Sketchup also, and it is usable for what it is, but compared to Onshape it is just a toy when it comes to modelling of mechanical parts. Sketchup is better for architecture I guess, since you can model a house in an environment, but as I said, for modelling all kinds of parts, Onshape is in a different league.
I have decided to buy new iMac
These things are incredibly annoying, and since I can actually open some of my other documents, this must mean that something crashed with the document that I was working on. Or to be precise, one of tha part studios in the document I was working on.
How can these issues be tracked down?
Edit: While I wrote this, it suddenly came back to life, but I could actually reproduce that same fault by re-trying the same operation, so now it hangs again.
I've cleaned all this up now, and the offending document was also deleted. It wasn't an important document, fortunately. Just some testing and experimentation I was doing.
But I'll make sure to try submitting the next time I get into something similar.
on a group project with my school mates. Unfortunately, the thing that isn't working is the main assembly, which we really need to pass our project. It was working on other computers, but not the one I have at home, which makes it difficult for us to work on the project all together. It won't come back to life, like stated above, despite multiple days, refreshing, clearing cache, and multiple separate log-ins and attempts.
With regards to " It was working on other computers, but not the one I have at home", is this still the case? If so, how is your computer different from the others - for example - OS, browser, CPU/GPU capabilities?
Please file an issue so we can investigate further. Look for "File a bug" or "Feedback" under the ? dropdown.
Drawing with vellum is faster than drawing with OnShape.
The other may have just been a fluke.
But I can tell you this is not the norm. Onshape in generally very stable. They just released a big update yesterday that may be part of the cause here. Usually, they have this fixed in a few days and everything is back to normal.
Also, I would generally recommend avoiding modeling threads due to their performance impact, but if you do need them there for 3D printing or some other purpose, I would recommend using a custom feature like External Thread or Internal Thread to save on manual steps.
