Helix inside non-conical surface - sweeping help needed for inverted auger.
curtis_vancura
OS Professional Posts: 18 PRO
I need to build an auger on the ID of a conical surface that extends beyond the ends of a cone. I have succeeded with the sweep on a cone, but the rest is beyond me at this point. I profiled a cone with extensions at either end, but now it is no longer a cone. What can I do to achieve this?
https://cad.onshape.com/documents/31dc949cf73af5a900907bcb/w/93176645c3c6b511d132b6f8/e/8cf241cb47870a2f876b8428
Link: https://cad.onshape.com/documents/31dc949cf73af5a900907bcb/w/93176645c3c6b511d132b6f8/e/8cf241cb47870a2f876b8428
If you scroll down, there's a guy who shows how to smoothly connect helices of varying pitch and turns.
