Dynamic Editing of a Spring
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
With the addition of helix in the last build, I thought it was cool to see a spring dynamically update while editing the cylinder that defines it. Take a look...
Editing the cylinder and using the Final button allows the entire Part Studio to solve while you make dynamic edits. Thought I'd share... ~Lou
6
Were you stalking my document?
Really cool spring behavior, btw. Will this integrate into motion studies too (assemblies)?
Dries
http://www.deelip.com/?p=1296
Kevin is correct, other products have implemented dynamic springs. Some do real geometry, some use graphical tricks. However that does not diminish the coolness factor of lou's example. Onshape is using real geometry.
Joe
Thanks
Dries
