Pretty close on Android
First of all, I know this is not officially supported, but here is how close I got to using OnShape on my Android tablet.
Step 1 - Enable WebGL in Chrome (in my case I had to use chrome://flags and turn on hardware acceleration because my device is on the HW accel blacklist by default)
Step 2 - Request desktop site - this just seemed to help with getting the viewport sized properly, without it the menus and sidebar were cropped out and I couldn't scroll to them)
This got me close enough to view my model, but I hit two obstacles:
- input in the view would not register; tapping on the sidebar then seemed to result in my previously ignored input to be sent an event at a time to the view
- the orientation cube was shown cropped at the bottom of the screen, so I could not rotate the view interactively this way either
All in all, it seems like OnShape may not be that far from working on the latest Android Chrome, and it looks like performance on my Galaxy S is good (I did notice some rendering artifacts, but they are likely due to the OpenGL drivers on the device)
Really the only thing that seemed off was the exact screen layout, and that may be due to the aspect ratio of the browser when I use the tablet in landscape mode (so improving that would probably help in general). It would be interesting to see what UI can be designed to substitute for the lack of keyboard shortcuts - the toolbar is not quite it.
Lou, Chrome Guru that you are, what do you think? Also, android app = moot point to above issues?
LearnOnshape facebook group
So… try the mobile clients and send us your feedback, it will influence more than just one app in the coming months.
Yes, Lou Gallo is most likely going to be sending out the invites when we start our Android alpha/beta.
would also like to beta the android app. I assume you are going to do the beta testing through the system supplied by google? A google+ beta community.
I guess "Mark me down".
Mark
Kevin.
Google Play is saying "This app is incompatible with all of your devices."
As it only has Android 4.2.2, this must be the reason.
