Improvements to Onshape - May 24th, 2017
NeilCooke
Moderator, Onshape Employees Posts: 5,988
This latest update is heavily biased towards Drawings and our ongoing efforts to add more tools for creating complex geometry. As always, our development is driven by you, so please keep those Improvement Requests coming by posting your ideas in the Improvement Requests category on the right of this forum. Let's dig in!
Please take a moment to try out these new features and improvements and let us know what you think!
LOFT WITH PATH
You can now control the shape of a loft using a Path. Intermediate sections added at regular intervals along the Path create a smooth transition between each Profile. The number of intermediate sections affects the smoothness of the loft.SHOW CURVATURE
You can now show the curvature of all sketch entities, curves, and model edges to check for inflections, tangency and curvature continuity.NAMED VIEWS IN DRAWINGS
You can now use Named Views to place a view in your drawing. This is ideal for when you you want to create a view of a specific feature or you need to reorient your drawing views differently from your model views.CUSTOM SHEET SIZES
You can now edit a Drawing's sheet properties and create a custom size. All borders and title blocks will resize and move to fit.FORMAT LOCK, TABLE GRIP POINTS AND VIEW UPDATES
You can now lock a drawing format to prevent any accidental changes to the title block or drawing borders. Tables have new grip points specifically for moving and resizing which make it much easier to size and position tables on your drawings. Existing views now stay on the screen longer during a drawing update to make it easier to visualize the changes to the drawing.EDITING GTOL FRAMES
You can now remove the last frame in a geometric tolerance to make editing easier. The Composite option now adheres to standards, only permitting its use with True Position, Profile (Surface), and Profile (Line).SELECTION FILTER FOR SHEET METAL FILLET AND CHAMFER
Onshape will now filter out all sheet metal edges that cannot be filleted or chamfered. This makes it much easier and faster to select the small corner edges.RECENT CHANGES NOTIFICATION
If somebody has made changes to a Document since you last opened it, a notification will let you know and highlight each of the changes in the Versions and History flyout.FILTER ADVANCED SEARCH RESULTS BY VERSION OR WORKSPACE
The advanced search capability added recently lets you search within your Documents to find Parts, Assemblies and Drawings based on Name, Description, Part number, State and Revision. A new "Results from" field now lets you filter your search results to display content by Workspace and/or Versions and to display all Versions or just the latest. This is particularly useful when searching Documents containing numerous Versions to help you quickly find the Part, Assembly or Drawing you're looking for.
GRAPHICS PERFORMANCE
Onshape now automatically reduces the level of detail on screen when rotating large assemblies with lots of parts to increase interactive graphics performance.ASSEMBLY SECTION VIEW PERFORMANCE IN DRAWINGS
Creating a section view in a Drawing of a large assembly is now significantly faster.IMPORTING SPLINES IN DXF FILES
Onshape is now more tolerant when importing DXF and DWG files which contain splines with discontinuities. More complex imported profiles can now be used in sketches to create other downstream features such as Extrude and Revolve.Please take a moment to try out these new features and improvements and let us know what you think!
5
https://cad.onshape.com/documents/5f57a1324ecbaf04ca6a5f78/w/c2be780bedd176ed489d472b/e/e195562e764d93c098daf479
What's strange is that it opens up in a drawing just fine other than a crazy initial zoom.
Great additions as mentioned above! Keep up the good work!
Kind Regards
Stephanus Mentz
+1
That was needed....
I've got one library that's up to V44 now. Sifting through that long list got to be annoying real quick.
Thanks!!
I am really enjoying the drawing improvements. These are exactly what I need, hoping to see weld notes come in really soon too.
Also of note; If you double click on a dimension we will fire the dimension panel with focus placed in it. When focus is placed in the dimension panel, then your cursor can be anywhere on the drawing and the panel will stay open. We make the assumption that you have been deliberate in intending to change something via the dimension panel, and don't want a hover out to close it too easily. When focus is on the panel, then a click outside the panel or a press of the escape key will close it. See the animated GIF:
My # 1 was custom sheet sizes
I briefly tested this on a couple "heavy" public models and it looks like it really makes a difference.
- Named views in drawings finally makes drawings usefull for me too
- Document search can now be actually used
- Graphics performance just got awesome and gives a whole new meaning for a laptop*
*I was just in exhibition and needed to show my 3D factory layout to machine maker, I immediately told that it might not respond using a laptop but that I would try. Model with 120739 faces, 4193985 triangles, 257411 edges and 1104949 lines runs now smoothly on Thinkpad X1!! Amazing surprise as I didn't know there was update pushed in until now
This assembly was on the edge with an older version of SW.
OS, with this latest version, is handling this with ease.
Keep rocking out!
1) I no longer have to click my name before clicking "Sign in."
2) As long as Chrome is open, I can close and reopen Onshape without having to again sign in.
3) "Shaded without edges" now looks GREAT! Exactly how I wanted it to look.
Thanks!
All your improvements are great.
