"TO DO LIST" in Onshape
AgersensAgersens Member Posts: 10 PRO
Is there a way in Onshape to add a document (Text or Word) that is editable so I can make a "To Do List" in Onshape.
I want this to be seen and editable by myself and other design partners.
Thanks Steve
    there are notes and featurescript text editor, which can be used for this :*
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
    There's also comments and the document description or workspace properties.
    For advanced version of todo list you could use google sheets and link that to document.
    https://forum.onshape.com/discussion/6576/why-onshape-documents-make-you-more-productive-on-the-manufacturing-floor
    edited June 2017
    I think comments would be a good place for a To do list to live. I just tried adding one to the doc I am working on, you can also tag people in using the @ symbol which is pretty cool too. However, the To do list will get pushed down the comments list as others comment, ultimately the ideal thing would be for a Google-style doc to live as Onshape document tab.
  • barry_gibsonbarry_gibson Member Posts: 31 ✭✭
    just a bit of topic, but what does a but buster do, all sorts of things come to mind ???
    Paper roll cutter
    well you learn some thing every day.
  • AgersensAgersens Member Posts: 10 PRO
    Hi thanks for the feedback - I will look at adding google sheets.
    Cheers Steve
  • andrew_kleinertandrew_kleinert Member Posts: 97 PRO
    I think there is a place for explicit todo functionality.
    The comments do kinda do a very basic function, but they don’t have any traceability or workflow around them that fits into any design review / engineering change control processes.
    Obviously enterprise users will have their own systems that provide this functionality.  But I still think there is value having it tightly integrated into Onshape design workflow.
