Improvements to Onshape - July 6th, 2017
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221
edited July 2017 in New in Onshape
We have an awesome update for you!  This update includes major new surfacing tools, a new drawing view tool, improvements to Loft, Hole feature, and more. Let's check it out.
FILL
You can now create a surface defined by a boundary of edges or curves.
https://onshape.wistia.com/medias/393p878uxu
ENCLOSE
Create a solid part from an enclosed selection of surfaces or planes.
https://onshape.wistia.com/medias/ytmctcbiyz
GUIDES AND END CONDITIONS IN LOFT
You can now use a combination of guides and end conditions in the Loft command.  In the past, you had to choose one or the other.
https://onshape.wistia.com/medias/vogp8sj841
SECTION VIEWS AS NAMED VIEWS
If you are in a Section view, and create a Named view, this will be saved with the Named view.  Meaning when you return to your Named view, the Section view state is also restored.  Great if you find yourself repeatedly creating the same Section view.
https://onshape.wistia.com/medias/6dqbxhsgrw
HOLE FEATURE IMPROVEMENTS
There were many improvements to Hole feature with this update.  Including new standard hole sizes, and the ability to create holes in sheet metal parts.
https://onshape.wistia.com/medias/j3i90p5o9g
SECTION VIEW IMPROVEMENTS
You'll find a new "Angular" section view type in Onshape Drawings.  This option allows you to create section views at an angle. Also added with this update is the ability to change a view's label.
https://onshape.wistia.com/medias/zx7arvoklv
COPY/PASTE CONTEXT MENU IN ONSHAPE DRAWINGS
You can now right-click "Copy" and right-click "Paste" entities in Onshape Drawings.  In this past this was limited to keyboard shortcuts.
WELD SYMBOL IMPROVEMENTS
A few important improvements to Weld symbols were added with this update.  Including live updates to the Weld symbol preview, as well as support for staggered welds.
ORDERED ARRAY OF FEATURESCRIPT PARAMETERS
The foundation has been laid to allow you to make per selection changes to parameters in Onshape while creating a feature.  This means you can have different settings for each selection within a dialog.  Currently, you can only see this in the Fill command (where you can make "per edge" continuity choices), but we are working on more features with this capability. Below is an example of the custom "Port Feature" that has been modified to allow the user to change port size for each selection.
PERFORMANCE IMPROVEMENTS
Performance has been improved in several areas including assemblies, drawings, holes and more.
Please take a moment to try out these new features and improvements and let us know what you think!
«1
  • darren_13darren_13 Member, Developers Posts: 120 PRO
    Awesome update! Interesting featurescript addition here too, cheers guys.
  • WinkWink Member Posts: 4 ✭✭
    I need this update, specifically, it doesn't seem to be available in us-west-2, when will I see it?
  • cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221
    @Wink  New features are live for new Documents right now and existing Documents after they have been upgraded (normally a few days).
  • derek_wardderek_ward Member Posts: 70 EDU
    Great improvement Onshape team!
    @cody_armstrong Thanks, creating a new project did the trick.
  • albjerrealbjerre Member Posts: 25 ✭✭✭
    Yeah. Finally proper surface modelling. Now we only need 3d sketches.
  • Pascoe_DesignPascoe_Design Member Posts: 18 PRO
    Thanks for a really excellent update - now the surfacing tools are looking very good!
    For the future, together with 3D sketches, we really really need the ability to show surfaces in drawings.
    Awesome stuff as usual :)
  • 3dit_software3dit_software Member Posts: 5 PRO
    Thanks for the update. Special thanks for
    1. Holes in Sheet Metal
    2. Loft improvements
    3. Fill
    As I'm using a lot of pins for alignment, I hope the next update will expand the hole feature to pin holes (clearance & press-fit)
    Or just let us have more options under "Custom"
    checkbox for thread with diameter / pitch / depth (that shows up on drawings and hole callout)
    Textbox for notes that can show up in the drawings hole callout ("press fit" / "slip fit" / "Fit to sub detail 16513_a"... etc..)
    That way if they are missing a thread size ... ahem.. M18x1.. M12x1.... We can still call it out in design  using custom hole option.
    Then OS won't have to worry about EVERY hole possibility.
    Great update!
    For the holes I would like to see quick menu for say 10 user holes - for me that would be all I need in 95% of time. User hole should include all data so it's just one click to proceed + edit if needed (preset values).
    And I had also something else in my mind.. what was that.. um.. yeah, CONFIGURATIONS - I'm ready if you're ready =)
  • daniel_splawskidaniel_splawski Member Posts: 66 ✭✭
    How would 3d sketches work?
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 872 ✭✭✭✭✭
    Great update. Kudos on hole command for sheet metal! Keep the sheet metal enhancements coming!
    Bryan Lagrange
    Twitter: @BryanLAGdesign
    One additional change that we made with this update is that you can now set variables to more types of things -- arrays, maps, strings, and functions.  For example, if you set the variable gapClearance to function(length) { return length * 1.15 + 0.1 in; } then you can use
     #gapClearance(1.5 in) as an expression in later features.  Also, as a result of this, the parametric curve and surface custom features no longer need the suppressed variable step to work (@mahir, you may wish to update the documentation to reflect this).
    Awesome, like those a lot, thanks :)
    Beer o'clock Devs?
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    edited July 2017
    @ilya_baran nice! Now those FS won't be so clunky to use. I'll update documentation shortly.
    Update: The documentation no longer references the suppressed variable. This works sooo much better now.
    edited July 2017
    @ilya_baran now we need expandable string input fields in features and dimentions, and autocomplete to manage such long expressions >:)
  • SledDriverSledDriver Member Posts: 117 ✭✭✭
    edited July 2017
    " now we need expandable string input fields in features and dimensions, and autocomplete to manage such long expressions"
    2nd'd
    And can we PLEASE have indicators in the feature list AND in the Variable edit dialog box for when a variable is defined by a function, rather than a static value! The Variable edit dialog STILL shows only the final value until you actually click on the variable. Even better, have two lines - one for the expression, and one for the evaluated value. The variable below is set to 2*3, but there is zero indication of that an expression exists. This is error prone and makes things unnecessarily difficult. Surely on our big modern monitors we can afford an extra line in the dialog box, and a flag in the Feature list. :-)
    @konstantin_shiriazdanov I don't think we'll go down the path of every expression field becoming a tiny feature studio.  If the object you're creating doesn't fit in the expression box, a custom feature is the way to go I think.
  • robert_morrisrobert_morris OS Professional, Developers Posts: 170 PRO
    @ilya_baran I think what @konstantin_shiriazdanov is describing is the fact that if you put something simple like "#myVariable1 * (#myVariable2 + #myVariable3)" in the expression box, you can't see the whole equation. All you see is something like "#myVariabel1 * ", and that's it. You're stuck scrolling back and forth with the cursor keys to try and read the whole thing. You see even less in the dimension entry of a sketch. It would be nice to be able to expand the on-screen size of entry box so that you can see the entire expression.
    Exactly. The current situation is ridiculous and error prone.
    edited July 2017
    Just cannot agree with that at all. Have you ever tried to edit an expression in a dimension for example?? It's so bad.
    And suggesting that Onshape's power should be limited to those with developer knowledge is really unhelpful.
    I have programmed 3D CAD systems in assembler in my professional career, but I have no desire to write a custom feature every time I need an expression in a variable or dimension.
    @robert_morris @SledDriver
    Ok, I misunderstood the request.  What I meant to say is that we're unlikely to have the full power of the IDE in the expression box for writing complicated multi-line functions (where programming knowledge is already required).  However, I agree that the current box approach doesn't scale well even for moderate-sized expressions and some form of autocomplete is also needed.  We do plan to address this in the future.
    ...the fact that if you put something simple like "#myVariable1 * (#myVariable2 + #myVariable3)" in the expression box, you can't see the whole equation. All you see is something like "#myVariabel1 * ", and that's it. You're stuck scrolling back and forth with the cursor keys to try and read the whole thing. You see even less in the dimension entry of a sketch. It would be nice to be able to expand the on-screen size of entry box so that you can see the entire expression.
    Hell yes please, this drives me slightly nuts on occasion.  Is there an existing IR for it?
    Cheers, Owen S
    Cool, thanks.
  • dany_maruanidany_maruani Member Posts: 8 ✭✭
    It will help a lot if we can visualise the expression : perhaps a right click on the value will display the formula.
    @dany_maruani
    You get a preview of that if you mouse-over the variable in the tree also if that helps for the time being
    Great list of improvements. It's alway exciting to see what's on the list. Keep up the great work team.
    Hole feature supporting sheet metal was an important improvement, now I can add a tap hole and my dxf will come out with the hole to the tapping drill size.  I am not sure I like the countersink coming out at the outside diameter, I will quite often put countersinks in a sheet metal part after the hole has been cut or punched, this format doesn't suit this workflow. Also, the taping annotation doesn't seem to be coming into a drawing for a sheet metal part.
