Part Visibility in Assembly drawings, for illustrating assembly steps
mike_everman
Member, csevp Posts: 9 PRO
in Drawings
I was hoping to see in the recent update the ability to hide selected parts in drawing views. Maybe next time.
The limitation has lead to a work-around that has us making subassemblies for every step in a build-up.
A little tedious, but not too bad. Now, there's a tab for Step 1, Step 2, etc. which in a roundabout way may help us go paperless on the shop floor.
I still think that visibility should be a feature, though.
4
In the meantime, here is a Technical Briefing on a workflow that would enable you to generate your drawings.
https://docs.google.com/document/d/1eGI0eGWnurkIx50Q0H2KgX1anUChvYZJIPfblu2YoEQ/edit?usp=sharing
I was thinking about this the last couple days, if you create an improvement request, link it here and you will have my vote
The work is already scheduled
ps - Hey! Quit calling me 'complicated'!
@philip_thomas I am interested in your method for exploded views too. Do you have an explanation doc for this also?
You'll just have to wait a bit
Here is my Doc on how to do exploded views - i will probably do a webinar on this sometime in August.
Of course we are going to build a dedicated exploded inside Onshape, but there are still some big projects ahead of that, so in the meantime, check out some of these techniques . . .
https://docs.google.com/document/d/1UfDWBNfjqr4e5Zuau1QFQn2kgK-QnYGwP2pwG2DK6Vk
Now I'll test you, have you got an intelligent workaround to link the Balloons to item numbers?
Now onto the next thing
If you go to the Improvement Requests category of the forum, then click "New Idea" and start typing in the "Idea Title" block, it will do a dynamic search of just the Improvement Requests category. If what you're looking for isn't already there, you can type out your full Idea and submit it, IRs can be submitted by any customer!
To vote on an improvement request, go the the improvement-request category.
https://forum.onshape.com/categories/improvement-voting
from there you can search JUST in that category by clicking on the 'magnifying glass'.
This takes you to the advanced search dialog.
From there, you can search for your improvement to vote on.
If you dont find it - feel free to add one yourself!
I did create a new idea to add a query to the ir forum so we can find an idea to vote on.
search for "search new ideas for idea"
