Copy sketch elements within sketch?
I'm working on a design that reuses the same geometry in several places on the same sketch. Is there a method I'm missing that lets me re-use the basic geometries (after I kill the constraints locking them down) to different areas of the same sketch? Sort of a copy / paste (free floating), then I can move and snap them into the new locations required?
I see copy/paste for the parts, but it doesn't seem to currently apply in sketches.
Not sure if a shift drag would work in a browser or on mobile but a rmb click with a copy and paste option would be nice. (If an other method is not already available)
This initiated a shortcut for copying that geometry. The trick was to release the Control button before releasing the mouse button. This meant that instead of copying it, you just moved it. (Obviously it had to be unconstrained in the latter case, unless you had the appropriate options selected)
I think it was actually a nice, simple and elegant shortcut and it would be nice to see it in OnS; I can't understand why it remained undocumented in Sldwks.
I didn't see it because it isn't there if you select an area rather than a line.
