Can't access Offset Mate using Fastened Mate
Hello All-
I can't seem to access the Offset Mate dialog box using Fastened Mate, it doesn't display. Any tips?
Thanks in advance,
Devon Sowell
Thanks in advance,
Devon Sowell
Devon Sowell
Engineering Consulting Partner
Professor, Engineering Technology, Palomar College, San Marcos, CA
sowelldevon@gmail.com
760 809 9046
CarlsbadCAD Carlsbad,CA
760 809 9046
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 667
Ace_Deuce said:jramlsey said:This is a screw up on our part. This is a feature we were hoping to have ready for the last update but decided that it didn't fit the level of quality and user experience we intend for so we've decided not to release it yet.
Sorry for the confusion.
Just a comment, but offsetting a face of a part from another face in an assembly is basic. I shouldn't have to create a mate connector that is offset from a part just to achieve this. That just adds clutter to either the part tree or the assembly tree. I hope this feature (the offset check box in fastener mates) gets added soon. Other than that, the assembly process has been great.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
It's in the help, https://cad.onshape.com/help/#mate-fastened.htm updated the 9 of march. So I must be doing something wrong
I tried starting a new doc, I still don't see it. Onshape any idea's?
760 809 9046
760 809 9046
-Jim
760 809 9046
The error message disappears when I try to <Shift-Print Screen> the message says
"Mate connector 1 did regenerate properly: Cannot resolve entities." The Mate Connector is red as you can see. I picked the origin part. I'm still learning so perhaps I'm doing it wrong?
Thanks
760 809 9046
@LouGallo One question about moving mate connector, how do you know directions for x, y and z and what is positive/negative value direction without testing? First I assumed it's using global coordinates (which are visible on the cube at all time) but it's not..
The blue/z axis is always made normal to the face it is inferred from (outward facing), aligned with an edge, or aligned with the center of a cylindrical face.
RGB = xyz is pretty standard for CAD as you'll see it in SolidWorks, Solid Edge, Inventor, and NX.
