Improvements to Onshape - December 4th, 2017
NeilCooke
Moderator, Onshape Employees Posts: 5,929
Christmas comes early with the last update to Onshape for 2017! Let's get the party started with one VERY popular improvement request that will get you in the holiday mood...
CUSTOM MATERIAL LIBRARIES
In addition to the standard material library provided by Onshape, you can now create your own custom material libraries and share them with your colleagues.CREATE EDGE SELECTION
The Create Selection tool has been enhanced to enable quick selection of edges that are tangent, equal length, parallel or part of a loop.DRAWINGS
As usual, there are a number of performance and quality improvements to Drawings. In this update, view quality has been improved and moving dimensions is now much easier, but the biggest update is to the Drawing Sheets flyout which now lists every view on every sheet.VERSIONED DRAWING REFERENCE HIGHLIGHTING
When inspecting a version of a drawing, hovering your mouse over a dimension will now highlight the geometry that dimension is referencing to help you understand the drawing better.
QUICK ACCESS TO RECENTLY OPENED DOCUMENTS
When the My Onshape filter is active on the Documents page, you can now access your most recently opened Documents from the Quick Access area of the Documents list, without having to activate the Recently Opened filter.GRAPHICS PREVIEW
On larger Assemblies and Part Studios, Onshape will now display a graphics preview that you can pan, zoom and spin as the Document or Element tab is loading.ACCESSING THE LEARNING CENTER
You can now quickly access the Learning Center from within Onshape by clicking the new button in the top right hand corner.
7
Thanks for working hard on pushing out these updates!
Can't wait to get my hands on material library, and create selection edges (was kinda missing that from SW)
(b) Also love the new quick access do-dads, and the fact you can just zoom out to see more. Nice
(c) Edge selection gizmo also useful. We now need @3dcad 's suggestion on an automated "Philip-Bot" that points out to the user that they're doing it the hard way if it notices that you're not using it where appropriate. Actually is that as daft as it sounds?
O.S.
Edge selection is really useful, materials close second.
Rest of updates nice to have
1. Really liked the custom materials, now I can use any material I want! (rather dangerous)
2. New selection options are nice to have, they make quick work of the small round some plastic parts.
3. Drawing sheets and view logistical improvements are much appreciated.
Thanks for the graphics preview as well.
Santa next ?
Need to be able to assign a mass (weight) and inertial properties to a part.
TVP, Onshape R&D
I agree with the ability to add a custom weight, but here's a quick featurescript that just gives you the density needed to make your part a requested mass. The process of making material libraries is long, so this might not be that useful, but the feature could be extended to output the csv of all densities needed to make a series of parts have certain masses.
https://cad.onshape.com/documents/86809a3e3987a65b9de9b77d/w/a46bbc7650522765ca0c9cce/e/ced19a67fadd7ae81439b4a4
Max
In the spreadsheet if the color field for a custom material was left blank then assigning a custom material wouldn't change a part's current color.
Please create a request for voting, surely gets my +1
Custom Materials (including mass properties) are now available. Great. I am currently well advanced on creating a personal custom materials .csv file.
However, I was expecting mass properties for both OS and any Custom Materials to be available in the "Insert Sheet Reference Property" drop down for drawings, to be released at the same time. I was disappointed. I can't find an IR for this function so I can vote for it. Does such an IR exist?
I want to be able to modify my drawing templates, so that mass properties in my drawings populate automatically (just like other properties). Currently I have to manually copy the mass from a part studio, then switch to the relevant drawing and paste in the mass every time. Very time consuming and inefficient.
Is there a way to automate this process? The mass data obviously exists (if a material is assigned to a part), so It should be relatively simple to write code to do this. I am not a programmer, otherwise I would have a crack myself.
Under "Insert sheet reference property" in the note command, Add "Material".
You have to make sure your "sheet reference" in the sheet properties is set to a part and not a Part Studio.
We cannot add mass properties yet to the drawing. Please file an improvement request.
https://forum.onshape.com/discussion/7879/custom-materials-optional-color-info#latest
It took some lateral thinking but we think we landed on a solution that should very closely resemble the scroll speed/behavior that you expect throughout your system.
Please let us know if anything else feels unnatural. We don't like little things like this impeding anyone's workflow
Also it would be feasible for all if Onshape or others provided a material library for each materérial group (thermoplastics, rubber, copper alloys, stainless steels, etc). It makes no sense if we all should do so individually
This would also allow for planned obsolescence / seamless new material introduction.
Re Mass Properties implementation into Sheet References for drawings.
IR Raised here: https://forum.onshape.com/discussion/7920/implement-mass-properties-of-materials-into-insert-sheet-reference-dropdown-for-drawings/p1?new=1
Chrisjh777
