Helix+Swept Cut and a Curve
michael_mcclain
Member Posts: 198 PRO
I have a swept cable (circle) of constant diameter that runs along a path composed of sketch lines and fillets in an S shape. This is an armored cable and my client wants the helix cut armoring to be represented. My question is: Can I run a helix along this curving path to perform a thread-like cut along the cable? Does someone have an alternative idea so I can do this?
https://cad.onshape.com/documents/741763e1afe8154022dd9ee7/w/56d29bb710024777917516b6/e/ea9aeaa9ef434c9a9299bb58
Optionskonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭that requared 3 custom FS
https://cad.onshape.com/documents/ef9fa6faac8b07735caf069d/w/72628fde3e9fd77cd0298569/e/1d95747baca77b9b2ce8cce9
7 -
Optionskonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭the new algorithm for 3d inflection points handling seems to work good enough
https://cad.onshape.com/documents/f808efdf7d32c8ca78afee41/w/e0642d0e0b1ce441322e15d7/e/0bd10bd5485a79e22be1199b
5
Then add the feature script to your custom toolbar
It should appear for use in your part studio here, as you can see I have quite a few in my list.
FYI I have basic knowledge of Featurescript at best. I did the tutorial, but I'm going to leave that realm to the experts.
https://cad.onshape.com/documents/766fbcbb8a9c2196258e0f94/w/cb9e8bc9e88a5e7301db2b03/e/b849330e0df5fbfadfdf9382
Thank you! Did you create this custom feature? It would be useful if it had functionality for controlling the angle at which the spiral starts, just like the helix tool.
