How do I construct/model a rolled plate in Onshape.
Colm_Rev
Member Posts: 9 PRO
I did notice @john_mcclary had done some flattering with using the measure Feature Script to build a new flat sketch. There may even be a flattering Feature Script if someone can lead us in the right direction.
Which lets you make a measurement and then stores it in a variable:
From there I made a sketch "using" as much information from existing sketches. And as many constraints as possible.
Then I used the MD feature to set the length of the part
and also to set the spacing of the slots.
The result ls close enough for my needs. But doesn't account for metal stretching or anything. But that's why I use 2" slots when I roll form
Hope this helps
Hello, can you maybe make a video of the individual steps? I can not do this. Greetings HobieI didn't add any holes to the side wall, but you can copy this and play around with it. Just roll back to the beginning and you can see how I do this step by step.
If you still want a video, I'll be happy to do one, but it may be a few days away before I can get to that.
let me know!
Edit: Helps if I include a link to the document...
https://cad.onshape.com/documents/28050bca2b1ddeb0acbab720/w/72369ffa7faabbf84de28ab1/e/eb89dcc51a42945fad1bb5b1
When you create a Sheet Metal Model, choose "Thicken" at the top, then choose the face of the import that you want to use.
I was about to add a improvement request for lofted sheet-metal, cone is pretty much the same command anyways
Vote for it here:
https://forum.onshape.com/discussion/9297/loft-sheet-metal/p1?new=1
