https://catalog.pemnet.com/viewitems/ht-wall-thru-threaded-inserts-types-iuta-iutb-iutc/-staking-insert-straight-wall-thru-threaded-metric
Two item's we'd love to see:
Nylon-Insert Locknut
https://www.mcmaster.com/#90631A411
Thin Nylon-Insert Locknut
https://www.mcmaster.com/#90633A411
Carriage Bolts
But really looking forward to improvements in naming with proper descriptions so I know what I am looking at without expanding the flyout BOM and also search improvement, ideally even a way to combine parts from common standards like DIN and ISO, McMaster ui does this nicely. It might sound crazy but I am still downloading and using McMaster parts with removed threads. Another thing I also find it extremely useful to have head markings to prevent errors by being visible on the model.
Also when designing it is important to make sure nuts will not bottom out on threads and also to get shanks engaging in holes, some form of indication on the bolt to indicate this would help. You can see by the picture above I am flying blind atm. With my macmaster imports, I suppress the threads and un suppress briefly to check engagement. It would be super nice for an Onshape standard content to have a solution for this too.
When inserting it would be nice to get a preview of the part in the location's selected which would help the user to choose the right size straight up and also be great if you could select auto-creating MC while the dialogue is open.
And also Plastic thread inserts
Always excited to see more standard content. Coming from the architectural (as in buildings) space we’ve seen the power of content libraries being opened up for anyone to create & share or sell. Of course anyone can make content publicly available in OS but there’s no curating. So perhaps a sort of QC system from OS would be good(?). Particularly for niche items (clamps, sprockets, pins, extrusions, you name it), you guys will probably never be able to create it all. I guess what might be curated is simply interoperability & proper parametric standards? Perhaps mates as well?
I know that when we get a project which warrants it, buying the required (often niche) content is almost always the more efficient approach.
Duno, just kind of thinking out loud here of a kind of ecosystem that allows everyone to add to the repertoire.
I’m only starting to get into Onshape so I might well be missing something that already exists (pray enlighten moi)?
... I think I mean a featurescript equivalent for content.
I completely understand where you are coming from; I was a draftsman for a year in college. Having a project where a customer or contractor requires you to use a certain type of hardware for just this application means you need to source the content quickly.
There are big things in store for standard content in the future that I think will make you happy.
Edit: forgot emagdalenaC2C already covered this
Rivet Nuts (Or Rivnuts) In Metric, Not sure whether these would be better rendered as collapsed (after fitting) or before (as they come out the box) Steel.
Also, Rivets would be very handy (metric). Steel.
The following bolts were just added to standard content:
Thanks all for pointing us in the right direction and there definitely more in the queue. Keep them coming!
Jason
