Oshape is too slow, any idea for improvements?
i have a project in onshape i have been working on for the past 8 months, and it's getting realy complex. Onshape is proving to really not be able to cope with this complexity. my pc is powefull enough to handle way more complex assemblies in fusion 360. the project is getting too slow to even work on. i tried editing a sketch, i needed to project a single point from a context, and it took 35 minutes. 35 minutes that the pc was just sitting there. not using any cpu or gpu reallly. i would think that my interent is fast enough: http://www.speedtest.net/result/7442317093.png. do any of you have any sugestions on solving this issue? does premium give you better performance? or can i move this project to fusion 360 without losing all the parametric history? i really can't start over, however i can throw a small ammount of money at it if it will solve anything. here is the document: https://cad.onshape.com/documents/f4076b884bd69adfaafe9807/w/d82547b7b2d3e1309b28d8dc/e/70112a56ed6d7f27e2097759.
thx in advance, RUWO.
Jake_Rosenfeld
@ruwo_n_a
To answer a question you posed earlier but never got an answer to: upgrading to a better PC will help with interactive performance (rotating the model, section views), but will not help with regeneration performance (any change to any parameter of a feature, sketch, assembly). Regeneration performance is entirely on our side of the fence.Jake Rosenfeld - Modeling Team6
I wonder if you could simplify sketches in this part studio https://cad.onshape.com/documents/f4076b884bd69adfaafe9807/w/d82547b7b2d3e1309b28d8dc/e/d0abd5a76977909a1b77c9c9
To help clarify a few concerns of yours: your internet speed/band, in this case, wouldn't have an impact on performance. You can read about how we work here. Our paid offerings do not have a special impact on performance.
Which sketch and which part studio specifically were you having trouble with when trying to project a single point in context?
Twitter: @bradleysauln
As for simplifying sketches, I did not mean editing existing sketches - they are too heavy. I'd recommend modifying the approach. E.g. instead of using sketch pattern, you can cut out one hole and use face pattern to replicate it.
Try this tip here: https://forum.onshape.com/discussion/comment/36820/#Comment_36820
I'll keep poking at this too, and see if it gets better
https://cad.onshape.com/documents/e3a279a3a61f9eb98e166e1d/w/968bf2f032f637f35846302a/e/49a0e4e7ddd04ec75a83692e
@lana
@bradley_sauln
I'm not sure what you guys see when you clicked on RUWO's link, but this is my screen for the past 10 mins:
I think @derek_ward 's comment is on to something. The time reported in the Regen Time window does not match up to what we are actually experiencing. While Derek also made the observation that, though long, it did not take the 35 mins for him as RUWO did, I think that's just due to the difference between Derek and RUWO's client setup. For me, I can't even load the document.
Putting aside how Onshape "theoretically" works, it does seem that users with different client hardware setups are getting different user experiences.
There are a lot of red sketches in the document, it seems they are taking more time.
I'm using Chrome and a simple laptop
Other part studios are normal
I'm always using Chrome, and the problem of not being able to load a document had been encountered across 2 laptops (one Windows 7 and one Windows 10) and 1 thin client (Windows 10) desktop.
I'm located in Asia though. If it's not a client side setup issue, could the problem be the Onshape server serving different locales differently?
This is what I mean
Like I said, I had the same problem on all of my first 10 or so jobs. Because I kept doing the same mistakes. Eventually I found the strategy that worked. And now the whole job is smooth as butter.
It's a strange learning curve, you may need to rewire your brain a bit. But the end result is a complete model faster than I can even pack and go in solidworks...
Could you share with us some of these strategies that worked well for you? You've mentioned one point that is not keeping everything in 1 sketch. Besides that, what other strategies accelerated your design process and made everything smoother? Getting more elaboration on this will be more helpful for RUWO and also for many of us too. Thank you.
It's on a document that I am not able to share. So i'll put something together that you can access and feel the difference.
As a matter of fact I am having the slow problem with a model I am in, Above is a link showing what I was doing to speed it up. It is completely un-edited while I'm at work, so forgive the sloppiness.
It's sheet-metal/configuration based problems, so it isn't completely related to this thread's specific problem.
But you can see how small changes got faster and faster. In the end It was a re-design as I suggested should be done in this thread. (Yes, I follow my own advice even when it means starting over)
Thank you for sharing that video - a great insight into your process.
So far it appears just setting the ply parts to a version in the assembly may help speed up the assembly. It will still be slow if you make an update to the ply parts, but it shouldn't hold you back for other modifications when re-building the assembly.
See how fast it opens for you:
https://cad.onshape.com/documents/661b26036b612b3f518aaf8f/w/2ac4c8beddce171e3175f9af/e/4c65e09653b19f24fdf16cd5
