Mate Connector tips
Research_01
OS Professional, Mentor, Developers Posts: 301 PRO
Trying out some functionality, can anyone tell me if the video plays in your browser and if not can you let me know your Operating system, browser type? I am trying to find out the most universally accepted video type. Right now the MOV is the only type that autoplays in my browser.
https://cad.onshape.com/documents/4893f43ffb6c4955bb03d9ef/w/b072e6b39a244dd7903178d2/e/6c358725849d43d291c0ebbc
Nice video, no floating mating connectors between body instances? I hope this was registered as a bug.
I'm using Widows 8.1 Pro and Chrome
Dries
LearnOnshape facebook group
video
Video on the internet is frustrating and I'll try to explain what's going on. I've been frustrated with this for many years.
mp4 is a html5 video standard that should allow all devices & browsers to view a video on the web. Turns out the compression algorithm is where the problem occurs. The guys that wrote .h264 are holding browser companies hostage for $1,000,000 each. Microsoft paid it, google did not, not sure what firefox did. One day videos stopped working in chrome.
Google ended up buying a competitor to the .h264 guys and opened sourced this acquisition. So which compression algorithm should you use? Hell I don't know.
I read handbrake (a video conversion tool) uses the most compliant compression algorithms for video sharing on the web. I run chrome and since I run my videos through handbrake they work inside chrome and most other places without issues.
This was about 6 months ago, I now think things have changed and maybe theres a better way to produce a sharable video.
BTW .mov is an apple standard and works inside safari. Chrome has to load a quicktime addin to view. The . mov worked in the 32bit version of Chrome after downloading the quicktime addin. I've moved on to the 64bit version of chrome, after reading Joe Dunn's post, which will not show the video and doesn't download the quicktime extension.
I hope this helps with posting videos, please post more videos,
FYI I turn autoplay off on my website by choice so this won't work. More accurately, the video tag has this option turned off. I don't think you'll be able to post to OS and turn this on. You'll have to add a OS "feedback" and ask that they play a video document on load. This could be obnoxious if you had 2 videos because they would both start playing. I think it's best to start a video after load.
OMG I only have 14 minutes left to edit this forum post..... I guess if it's the 1st document (left most) this one could play automatically.
