Move Sketch to New Plane
in General
I've modeled a sink in the z=0 plane.
After finishing modeling, I see that I maybe should have modeled it in z=900mm plane, so that when I import in ArchiCAD, the sink is at the correct height.
Any way to just move everything and all subsequent operations? What's the best way here?;)
https://cad.onshape.com/documents/e97c0e9237c9737465501800/w/c208f56a6a1535670c9212de/e/04906193f3241e24d62e3c32
1. create a sketch using the RIGHT plane
2. create a plane which is offset to the RIGHT plane
3. move the new offset plane before it in the feature list
4. change the plane in the sketch to be this new plane
I can't make this simple test work;)
What doesn't work is this:
change the plane of the sketch first and then move the plane before the sketch in the features list.
I thought I moved it first, but guess not; thanks
Anyways, it should also work by moving it after, so that's a little weird, cause when I move the plane before it, it should be able to regenerate, unless this sequence is registered somewhere.
..instead of this:
..though, both should work, cause the end result is the same, unless this sequence is registered somewhere?
"The feature list is regenerated in order from top to bottom. If the plane is after the sketch, it does not exist as far as the sketch is concerned. You can only reference features before the current feature/sketch you are editing. "
The first thing you said was:
"The feature list is regenerated in order from top to bottom"
We agree on this
Then you said:
" If the plane is after the sketch, it does not exist as far as the sketch is concerned."
We agree on this aswell and both list of actions would have this condition that the plane is after the sketch. It might not be after the sketch before all steps has been taken, but after both list of actions are done, the plane would be positioned before the sketch.
Then you said:
"You can only reference features before the current feature/sketch you are editing."
This is basically the same as the last line.
I'm trying to understand, not trying to be difficult;)
They way I see it, they both end up with the plane being in front of the sketch, but the sequence is different. In this case, the actual sequence is recorded, but not visible to us.
Chances are your selection isn't being registered in the first set of steps. In your first set of steps, you should not be able to do step 3 at all, because if you go to edit the sketch, the offset plane should not exist, and should not be selectable. You can turn on "final" mode if you want to see the plane, but the plane will still not be selectable (because it is being built after the sketch). Maybe there is some misunderstanding about what is actually in happening in your first set of steps?
